something in rear leaking
Old Aug 2, 2005 | 01:05 AM
TTlord's Avatar
i have a question. i got as far under my z as i could without a jack, to look at my exhaust, and noticed something depositied on my floor. looked up and the rear axle had something on it. i looked as best i could and noticed it was comming from above. i plan to jack the car up tomorrow and check it out. any ideas befor i get into it? the reason why i was looking at my exhaust is because i am replacing my stock with the catback slp lm. anyhow it is a 94 z. any help would be appreciated, i am not exactly a wrench. i havent really looked to hard but anyone know what gears were put in these?
Old Aug 2, 2005 | 01:48 AM
Z28SORR's Avatar
Re: something in rear leaking
These cars are notorious for pinion seal leaks. Thats the front seal on the differential.
Old Aug 2, 2005 | 09:07 AM
johnnyb's Avatar
are they worth changing or just forget about it?
Old Aug 2, 2005 | 09:09 AM
Bow94z's Avatar
defintly worth fixing, the pinion seal itself from a GM dealer is like 17$. you dont wanna dry up your rear end and have it lockup on you now would you? .. its only gonna get worse
Old Aug 2, 2005 | 04:14 PM
TTlord's Avatar
ok well i got er jacked up and ready to install my exhaust when i get it tomorrow. anyhow i got a chance to look at the leak in the rear. i noticed that the leak was actually comming from the drain plug. also i noticed that where the two axles have some build up on them, where they come out from the pumpkin??, but nothing bad. i will probably remove the drain plug and add some tefflon. and replace. everything else looks good.
BigWil
Mar 29, 2015 12:24 PM
WildRidez
Feb 23, 2015 07:24 PM
ChrisFrez
Feb 22, 2015 08:47 AM
alex5366
Feb 17, 2015 10:43 PM
blac94Z
Nov 24, 2014 07:12 PM
