When my car (with a Street Twin) sits for very long the clutch sticks. Why?
Old Aug 5, 2005 | 06:10 AM
JWBerk94Z's Avatar
Hey guys, I am curious if I did something wrong.
My car is having some oil pressure issues right now, so it has sat for a month or so. I went to move the car the other day and the clutch was stuck. I started the car with the clutch pedal to the floor, and it moved. Put it in N and started it. Let it warm up. Shut it off. Put it in 1st, held the clutch and brake. Cranked it until the clutch disengaged. It also did this after I had it parked for the winter. (Make sense????)
I installed the clutch myself. Did I miss something? I am thinking the disks are just surface rusting to the tranny shaft. Has anyone else had a similar problem? I wanted to lube the shaft when I put the clutch in, but I was afraid the lube would sling out onto the disks. Is there something I should have used?
TIA
LeftoverChinese
Jan 14, 2024 03:03 PM
USAirman93
Nov 24, 2014 03:37 PM
Queens94z28
Nov 20, 2014 06:03 PM
Snoman73
Nov 17, 2014 07:22 PM
jmzlt1
Mar 13, 2003 07:26 AM
