4 channel rear
Old Jul 26, 2005 | 03:04 PM
SpeedDemon02SS's Avatar
4 channel rear
i feel somewhat retarded asking...but...
can someone please explain the difference between a 4 channel rear and a 2 channel rear...and why a 4 channel doesnt have a ring reluctor for abs and tcs.
thanks
Old Jul 26, 2005 | 03:36 PM
rngilliland's Avatar
Re: 4 channel rear
The 4 channel rear is the traction control rear. It has 2 reluctor rings. One on each side on the axles.
The other one is a 3 channel rear and is used in abs only cars. It has one reluctor ring on the differential.
Old Jul 27, 2005 | 01:20 PM
BadgeZ28's Avatar
Re: 4 channel rear
from your description, can I assume my 01 Z-28 with the traction switch on the dash is a four channel system? Thanks.
Old Jul 27, 2005 | 01:27 PM
Re: 4 channel rear
what do the reluctor rings do? if i was to replace my rear, do i have to replace them?
Old Jul 27, 2005 | 02:09 PM
Re: 4 channel rear
The reluctor rings are just rings with teeth on them. The spin in close proximity to the sensors providing speed information to the abs and traction control computers.
If you want to retain abs or traction control you need them.
Old Jul 27, 2005 | 02:14 PM
Re: 4 channel rear
should i buy new rings...or can i reuse the old one?
Old Jul 27, 2005 | 03:15 PM
Re: 4 channel rear
If you get a 93-02 F-body rear they will be there already. If you have abs only make sure you get a rear from an abs only car. If you have traction control get a rear from a traction control car. If you have traction control it may be possible to use an abs only rear if you swap brake backing plates and axles. I'm not sure.
If you mean an aftermarket rear you need to talk to the company selling it.
Old Jul 27, 2005 | 03:28 PM
Re: 4 channel rear
no, im keeping my housing...replacing the differential...eaton or auburn (havent decided yet)...do they come with new ones...should i buy new ones...or can i reuse mine...
Old Jul 27, 2005 | 03:58 PM
Re: 4 channel rear
If you have traction control you don't need to do anything. If abs only I would get a new one.
Chet1185
Feb 4, 2015 09:51 PM
ddr698
Jan 9, 2015 10:05 AM
siguy
Nov 27, 2014 10:07 AM
Brian Demeter
Aug 17, 2002 08:07 PM
