Help!!! Clutch Master Cylinder Installation
Old Aug 13, 2005 | 12:52 PM
93ZM6Tally's Avatar
Any tips on re-installing the clutch master cylinder. The U-bolt is diabolical. Only thing I can see would be to remove the brake vacuum booster, and that doesn't look like a picnic either. Any tips greatly appreciated.
Old Aug 13, 2005 | 01:17 PM
Lower's Avatar
Re: Help!!! Clutch Master Cylinder Installation
I came across a post a week or so back in searching for something else that spoke of replacing the U-bolt with to normal bolts. Seemed to make things a ton easier, but I can't speak for whether this is a good idea or not.
Just thought I'd throw it out there for you.
Old Aug 14, 2005 | 04:04 PM
respectirocz's Avatar
i changed the clutch master cylinder in my 3rd gen, alot more room than a 4th gen and i still had to remove the brake booster
but trust me once i removed the booster the master cylinder was ALOT easier to access, and u dont always have to disconnect the brake lines from the brake master cylnder just to get the booster out, who wants to bleed their brakes to fix their clutch?
BPS
9
Mar 5, 2015 10:51 PM
HectorM52
Jan 30, 2015 11:08 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
siguy
Nov 27, 2014 10:07 AM
