Tran's mount don't mount right.
Old Jul 21, 2005 | 03:23 PM
FifeDogg's Avatar
Unhappy Tran's mount don't mount right.
ok, so I bought a ES and a Prothane Trans mount. The middle hole on both don't seem to want line up. It is off the hole by about 1/4 inch. should I try and get the trans to shift over and get it to line up or should I alter the crossmember to make it fit? Thanks
Old Jul 21, 2005 | 03:34 PM
89385formula's Avatar
Re: Tran's mount don't mount right.
Can you pry the tranny over some? Mine didn't appear to line up at first but i pry'd it over and now its perfect.
Old Jul 21, 2005 | 07:29 PM
Jazsun's Avatar
I had that same problem, at first I made the mistake of drilling out some of the hole on the corssmember, then I realized I could pry the trans a little.
Old Jul 24, 2005 | 06:08 PM
Z28Nut's Avatar
While your under there, you should take a look at the condition of your motormounts if the transmission is shifted over to one side. A bad motor mount can cause that.
jb4xx
Feb 2, 2015 10:00 PM
CaRParts102
Dec 6, 2014 08:45 AM
siguy
Nov 27, 2014 10:07 AM
Jul 4, 2005 05:00 PM
LS1 RULZ
Aug 11, 2002 11:15 PM
