Question about tranny mounts..
Old Jul 27, 2005 | 11:49 AM
JeicetheDamned's Avatar
I put a poly mount on my transmission, and ive heard of the vibration problems that people talk about. But it only vibrates at high RPMs. Is that normal, or could it be something else?
Old Jul 27, 2005 | 11:56 AM
Bow94z's Avatar
Re: Question about tranny mounts..
i would think it would vibrate more cause its under load, i just upgraded mine to a LS1 tranny mount, no vibrations
Old Jul 27, 2005 | 08:51 PM
Well, I had the stock mount on my 2000 SS automatic, and broke it. So I put a poly mount on it, and now it vibrates pretty bad at higher RPMs. It's not really a problem since I don't gun it much anymore anyway, but I was just curious. If I put a regular one back on, do you guys think it would stop?
Old Jul 28, 2005 | 08:17 AM
LWillmann's Avatar
If the only change was the transmission mount, then putting a rubber mount back on the car should get rid of the vibrations, or at least soak them up.
However, it is possible that there was a vibration problem (maybe driveshaft out of balance or something?) there before that the rubber mount was masking, and you're just now feeling it with the poly mount.
I recently snapped my stock mount (1 year old) launching at the drag strip, so I replaced it with a poly one I had on the shelf. I'm getting lots more vibration too.
Old Jul 28, 2005 | 06:47 PM
Thanks. I'll probably put a rubber one back on soon. There's no need for a stronger poly mount really, since I haven't done anything to my car except remove my exhaust. Thanks again.
Old Jul 28, 2005 | 10:16 PM
JKDZ28's Avatar
Get the LS1/1LE mount, its a good compromise.
Old Jul 28, 2005 | 10:25 PM
Cmr0z28's Avatar
Magenta_Hearts
Mar 29, 2017 08:54 PM
Sergio
Jan 27, 2016 04:27 PM
importkiller94
Jan 17, 2015 09:03 PM
nballisru
Dec 14, 2014 05:01 PM
mattszm6
Dec 14, 2014 07:09 AM
