what gears
Old Jul 21, 2005 | 11:48 PM
tranz350's Avatar
what gears
i have a 95 trans am m6 is there a way of telling what gears i have in it or did the m6 come stock with a certain size?
Old Jul 22, 2005 | 07:26 AM
1SlowFormula's Avatar
Re: what gears
In that year the stock gears were 3.42's.. you can use the calculator in my sig to figure out what you have by putting in the gears you think you have and see if the RPM is the same when compared to the gear/speed indicated in the results...
Also you can estimate by marking the drive shaft and spinning the tire one full revolution while watching the driveshaft rotate and count/estimate how many times it rotated.. for example if it rotates just under 3.5 time then you more then likely have 3.42's, and if it rotates about 3 and 3/4 time then you probably have 3.73, etc. etc.
Old Jul 22, 2005 | 09:00 AM
2000GTP's Avatar
Re: what gears
Or you can check your RPO codes on a sticker in your door or trunk hatch, can't remember where off hand, and compare to these:
GU2=2.73
GU5=3.23
GU6=3.42
Old Jul 22, 2005 | 09:04 PM
tranz350's Avatar
Re: what gears
ok kool thanks i was thinking they were 3.42 but wasnt sure or had away to tell i will use your advise and find out
blkWidow
Apr 21, 2015 01:56 PM
CARiD
Apr 8, 2015 08:08 AM
alex5366
Apr 1, 2015 09:27 AM
ChrisFrez
Mar 22, 2015 09:12 AM
