Rear gear ratio?
Old Jul 24, 2005 | 03:54 AM
madcat's Avatar
Rear gear ratio?
Anyone know how I would find out what gears are installed in the rear axle on my '94 Camaro z28? Or am I better off taking it to a mechanic and having them open it up and check?
Old Jul 24, 2005 | 04:20 AM
99blackSS's Avatar
Re: Rear gear ratio?
I think on LT1s you can just look at the shifter (if it's an auto) and if you can select first gear it is 3.23s. If you can't I believe it's 2.73s.
Or just look at the RPO codes:
GU2 = 2.73
GU4 = 3.08(V6 autos)
GU5 = 3.23
GU6 = 3.42(V8 manuals)
Old Jul 24, 2005 | 07:32 AM
johnnyb's Avatar
the rpo codes are in your glove box in case you were wondering
Old Jul 24, 2005 | 08:55 AM
rskrause's Avatar
Moderator
The easiest way to find out if you can't get the RPO codes, or if you think the gears may have been changed is to put the rear end up on jackstands in neutal and rotate the rear wheels. The ratio between tire revolutions/driveshaft revolutions = rear axle ratio. Of course,you need to measure carefully as the ratios are pretty close together.
Rich
Old Jul 24, 2005 | 12:33 PM
madcat's Avatar
Cool thanks guys, this should give me something to do today. O' second question, I know on my shift plate I can't select "1". It will only go to "2" which you can see on my website. I'll have to double check but I think I might have 2.73. If I do have these gears are they any good? Or should I look into changing them?
Old Jul 24, 2005 | 01:08 PM
BLinindoll's Avatar
you have 2.73's.
Old Jul 24, 2005 | 01:38 PM
Bow94z's Avatar
you should change out the gears to 3:23's,3:42's,or 3:73's..the pickup is such a difference. when you buy gears make sure they are fro a 2 series carrier becasue that is what you have
Old Jul 24, 2005 | 03:46 PM
madcat's Avatar
I think I"m gonna have to do some research to see which of those gears would suite me best. Thanks for the info...
F'n1996Z28SS
Aug 23, 2023 11:19 PM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
Jul 4, 2005 05:00 PM
