Can't pop the driveshaft out. >.<
Old Aug 14, 2005 | 05:18 PM
ChronoGN's Avatar
Hi, I'm replacing my 2 piece steel driveshaft with a 1 piece and I'm having trouble taking out the driveshaft.
Its the back part of the driveshaft where it meets the rear end that is giving me problems.. I alredy took all the bolts out of it and got the two metal retainer things out. I pushed it forward but it won't buldge. I stuck a wreck in there and tried plying it out but it still work buldge. I sprayed some WD40 on there and took a pipe in there to ply it out but it just bent the pipe in half. I'm all out of ideas. I think the problem is that it is rusted together or just stuck in there really good because of all the donuts and burnouts I do. Anyone have any good idea for taking this thing out?
Old Aug 14, 2005 | 05:24 PM
teke184's Avatar
Re: Can't pop the driveshaft out. >.<
crowbar....
it's just stuck...keep trying
Old Aug 14, 2005 | 05:48 PM
2001NBMZ28's Avatar
Sometimes they're a little tough, but it'll slide forward. Never removed a two piece DS before, maybe it's the extra set of UJoints taking up the slack while you're prying?
Old Aug 14, 2005 | 10:14 PM
lt11997's Avatar
Just stick a screw driver in and pry it out, it shouldn't take to much effort.
Old Aug 15, 2005 | 09:19 AM
Did you unbolt the center bearing from the torque arm?
Noct
Jul 14, 2015 01:18 AM
blac94Z
15
Mar 2, 2015 12:00 PM
ddr698
Jan 31, 2015 10:58 AM
bfmv13trivium
Jan 14, 2015 09:57 AM
