Eaton Diff
Old Jul 26, 2005 | 09:04 AM
SpeedDemon02SS's Avatar
Eaton Diff
If i were to install a new Differential (eaton) would it come set up for ABS and TCS? Or do i have to buy the ring gears for both?
Old Jul 26, 2005 | 11:16 AM
1SlowFormula's Avatar
Re: Eaton Diff
If you have ABS and TCS then you do not have a sensor in your diff.. In other words you would just install the diff into your rear.. Plus I hope this information help you with the other thread you have going...
Old Jul 26, 2005 | 11:20 AM
Re: Eaton Diff
i thought there was a ring gear attached to the differential that controlls the sensors for ABS and TCS?
Im still not sure why my ABS INOP light no longer comes on...i know its not the lignt or a fuse though.
Old Jul 26, 2005 | 11:25 AM
Re: Eaton Diff
I assume by you saying you know it is not the light that means you see it come on when you first start the car and does the light check?? If not then why do you say it's not the light?
Also why would your ABS INOP ligh come on? are you having trouble with it? That light shouldn't come on unless your ABS is broke, ABS INOP (INOPreative)...
Lets hear why you think the light should be on??
Old Jul 26, 2005 | 03:01 PM
Re: Eaton Diff
because someone along the way told me that ABS INOP meant - in operation...i guess someone dropped the ball...
and also because before my big bang...whenver ABS came on...so did that light...
Old Jul 26, 2005 | 03:37 PM
Re: Eaton Diff
ABS is always on.. Are you refering to when it was actually pulsing the brakes under hard braking? then I would say go out and drive about 20+ MPH and nail the brakes it it pulses then it works, and the big bang fixed it... If the Brakes lock up in that test then the ABS system doesn't work right...
BTW, I have been driving f-bodies as daily drivers for about 7 years and only activated the ABS twice, activated meaning hit the brakes hard enough to pulse the brakes...
Old Jul 26, 2005 | 03:39 PM
Re: Eaton Diff
it only happens on wet roads, or sand....
Old Jul 27, 2005 | 07:15 AM
Re: Eaton Diff
What happens? the ABS pulses or it locks up? if it pulses and the ABS INOP light doesn't come on then you are good to go...
BTW, I remeber a few years back my ABS INOP light came on a few times in sandy/gravel roads, I think that is just a problem with it reading the wheel speed diferently in those conditions...
Seriously though, if that light doesn't come on then you should be fine, Just make sure the ABS actually works...
Good luck.
Old Jul 27, 2005 | 08:20 AM
Re: Eaton Diff
it seems to work...i slammed the brakes on a dirt road...evertythgin fine...the pedel pulsates, and low trac comes on...so i guess im good to go.
revrider
Cars Wanted
Apr 5, 2016 10:06 AM
Henson071
Sep 18, 2015 04:01 PM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
realistyc
Jul 28, 2015 07:32 PM
