air to water intercooler question...
Old May 2, 2006 | 04:45 AM
bowtiepwr's Avatar
>If I was to run an air to water intercooler on my T-Trim can you run on the street without the water part and just fill the water tank when necessary? or will this damage the whole intercooler?
Old May 2, 2006 | 05:25 AM
Geoff Chadwick's Avatar
Re: air to water intercooler question...
Well If I'm getting what you're saying, you want to run it without water in some way shape or form. At that point its just an aluminum heat sink... Which isnt going to cool anything. Sure you could get away without running any water in it(if you can prevent knock) but why would you want to?
Having problems running water in it on the street?
Old May 2, 2006 | 09:30 AM
OBE1 95Z28's Avatar
You would have to disable the pump as it is wired to run anytime the ignition is on. The intercooler will very helpful to keep your intake temps down on the street; I have the Vortech Aftercooler on my 10# S Trim and see 40 - 50 degree F lower intake temps on the street since I added the Aftercooler.
Old May 2, 2006 | 11:08 AM
JZ 97 SS 1500's Avatar
Water to air is fine for the street. Just make sure you use a heat exchanger for daily driving, it will keep the water cool, and close to ambient unless you run at long extended amounts of time under boost.
Jose
Old May 2, 2006 | 01:59 PM
bowtiepwr's Avatar
>Thanks
I was wondering if It would be the same as an air to air (but with water).
Forced Inductions claims that their intercooler can handle up to 1300HP.
http://forcedinductions.com/GMkits2.htm so I will use this for my T-trim.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
95chwagon
Jan 13, 2015 09:19 PM
BLOWNBIRD
May 28, 2003 01:02 AM
