Best spark plug for supercharged 383 w/ AFR heads?
Old May 18, 2006 | 02:03 PM
CALL911's Avatar
What are my options for spark plugs for my 383 LT1 that is soon to be supercharged. My heads are AFR heads ported by TPIS. I plan on running somewhere between 12 and 15#'s of boost with a D1SC. I am aware that Autolite's are popular for the AFR heads, but I wanted to know specifically which ones would be best for my application. Also, are Autolites the only ones I could use? Are there any others that would work well with my set up? (NGK for example?)
Old May 18, 2006 | 02:25 PM
mzgp5x's Avatar
Re: Best spark plug for supercharged 383 w/ AFR heads?
I have used NGK, but, now I discovered the ZEX plug for SC or NO2 applications. I decided I like them. Engine seams to run alot better.
383 D1 - 15psi pulley w/ Spearco IC/ afr 190 heads/ Acceleronics w/ LT1 edit.
Old May 18, 2006 | 02:39 PM
Pullngz's Avatar
Part number, heat range, gap? Sounds like a pretty close match to what I have.
Mike
Old May 18, 2006 | 03:10 PM
mzgp5x's Avatar
Zex.com
82071-8 POWER RACER™ V8 SPARK PLUGS
$56.58 for eight.
Gap 0.033 - LT1 application.
Old May 18, 2006 | 03:35 PM
Pullngz's Avatar
Sweet, Thanks dude!!
Mike
Old May 18, 2006 | 04:21 PM
engineermike's Avatar
Autolite 3923. Plug must be gasket seat for AFR heads. NGK TR6 are taper seat.
Old May 18, 2006 | 11:10 PM
Kevin Blown 95 TA's Avatar
I got the Champion rep sending me some RC10YC and RC9YC plugs to try in a a similar setup. Past that I would need the 59's or maybe 63s which were developed for drag racing - they are built tougher for blowout, but they have no resistor. I'll try NGK plugs if none of these don't work.
Old May 19, 2006 | 09:35 AM
Sean94Z's Avatar
See this thread ..
http://web.camaross.com/forums/showt...ighlight=spark
Old May 19, 2006 | 11:26 AM
CALL911's Avatar
Good info on that thread thanks. Sounds like NGK's are out for sure!
Old May 19, 2006 | 12:19 PM
Sean94Z's Avatar
I wouldn't say NGKs are out for sure. I would run their V Groove Racing Plugs as listed in that thread. The big Turbo guys swear by these plugs..
Old May 19, 2006 | 01:04 PM
CALL911's Avatar
Oh. I though I read that the NGK's wouldn't seat right to the AFR heads. Maybe I didn't read it carefully enough and labeled a particular NGK to all of them.
Old May 20, 2006 | 06:16 AM
Sean94Z's Avatar
Yea, any taper style plug will not seat right with the AFRs. TR6's, TR5's, Autolite 103's, 104's, etc.. You just want to make sure you get a gasketed plug. I am running Autolite 3923s and like them, I have a set of the NGK V-Grooves waiting to go in next..
--Sean
Old May 20, 2006 | 07:46 AM
With the NGKs the R5671s and R5672s are gasket seat, with the 71's being non-projected tip design (probably better for nitrous), and the 72s projected tip. They have various heat ranges in each style - 71s in 7, 8, 9, 10 & 11 and 72s in 8, 9, & 10.
Highlander
Jan 12, 2020 02:13 PM
MadMav
Feb 6, 2015 11:02 PM
Jazsun
Dec 29, 2014 12:14 PM
Highlander
Aug 9, 2002 02:30 AM
