Procharger oil return and canton pan?
Old May 6, 2006 | 12:13 PM
blown383's Avatar
I did not want to punch a new hole in my new Canton oil pan so I was wondering how did everyone utilize the oil provision thats already built into the pan on the passenger side? Here is a pic:
-B
Old May 6, 2006 | 04:34 PM
lethal93ta's Avatar
Re: Procharger oil return and canton pan?
I was just looking at the same thing on mine, Im going to weld a fitting in the front corner of mine tho, that plug on the kick outs arnt a good spot for a return sence its already under oil it might have a hard time returning all the way back there.
Old May 6, 2006 | 07:03 PM
markinkc69z's Avatar
Exactly as above. Do not install the return in the fitting in the sump. That fitting is for a temp gauge. The return should be as high as possible. The flow rate of a P600B is about 1/2 qt a min @ 50 psi and standard 10w30 oil. The D1/D2 steps up to 2 qt a min. That really needs an unimpeded return path to keep from having seal issues.
Old May 6, 2006 | 08:49 PM
blown383's Avatar
Umm... then where do you guys suggest that I weld in a bung? Is a welded bung better than say fuel bulkhead fitting?
-B
Old May 6, 2006 | 09:05 PM
lethal93ta's Avatar
Im going to make a fitting to weld in so if I ever get a SC series charger then I can just put a plug in there, Im putting the plug right in the factory spot, on the front driver corner as high as I can get it.
Old May 6, 2006 | 09:18 PM
lethal93ta's Avatar
O BTW did you check the fitment on your pan yet? I had to bend in the crank scraper a little on my 383, but I have big manley h beam rods, just make sure they dont hit on yours like they did on mine.
Old May 7, 2006 | 04:34 AM
blown383's Avatar
The pan cleared my H-beam rods however the machinest had to bend my dip stick tube and notch the baffle a bit get the dip stick tube to slide in. Other than that its good.
-B
Old May 8, 2006 | 01:19 AM
blown383's Avatar
Also does anyone have pics of the bungs welded on their Canton pan?
-B
Old May 23, 2006 | 11:13 PM
lethal93ta's Avatar
Old May 24, 2006 | 02:14 AM
blown383's Avatar
Thanks for the pics! Do you happen to have any pics of it installed? Also was that braised or MIG welded on?
-B
Old May 24, 2006 | 04:43 AM
lethal93ta's Avatar
my motor isnt in the car yet, I mig welded mine.
Old May 24, 2006 | 09:30 AM
blown383's Avatar
Cool! I'm assuming thats a steel -8 AN fitting?
Old May 27, 2006 | 10:56 AM
lethal93ta's Avatar
yes 8 AN its an earls weld in fitting.
Old May 31, 2006 | 03:33 PM
97WS6SCharged's Avatar
Here's mine. I had a 1/2" npt fitting welded into the pan. The first fitting is a 1/2 npt to -8 adaptor and the 2nd is a -8 cap. I'll use a 90 degree hose fitting when I install the blower in the next few months. I'm still trying to get the thing ready to start.
Old May 31, 2006 | 06:03 PM
blown383's Avatar
Thanks for the pictures guys! Once I get the engine on the stand I'll mock up the blower and will probably go with a -8AN bung and lines to the blower. does anyone know what size the oil outlet bung is on a D1 procharger?
-B
HectorM52
Jul 30, 2017 11:46 AM
SergheiS
Apr 26, 2015 08:15 PM
SpeedJunkee
Apr 23, 2015 09:51 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
