max psi?
Old Apr 20, 2006 | 03:37 PM
blahster's Avatar
max psi?
I am contemplating dropping an STS turbo on my Z...MAYBE...have not decided yet.
I have a 355 with forged pistons...stock rods...stock crank...and LE3 heads...and LE3 cam...i estimate about 10.6cr....what would the most boost i could run safely be? if recommended at all? i realize this motor is not setup for it...but i would like to have the option to add a small amount of boost later on...i was thinking something like 9-10psi....enough to get me over the 500hp mark...i am looking at around 400rwhp right now...
Any ideas?
Thanks.
Old Apr 22, 2006 | 03:39 PM
boosted_6.0L's Avatar
Re: max psi?
Any ideas?
Thanks.
That compression will limit you on how high of boost you can run. 10psi is doable though. Remember to have a good tune and fuel
Old Apr 22, 2006 | 07:41 PM
NYSS Guy's Avatar
Re: max psi?
I have run 8 psi on the stock bottom end. But it has to be intercooled. On a forged bottom end, I would agree that 9-10 should be doable.
Old Apr 25, 2006 | 07:37 PM
NHRA's Avatar
Re: max psi?
8psi is possible and will surely get you that 500 HP. You may want to swap a different cam in place of that LE3.
KYWes
Jun 14, 2022 06:52 AM
13qtr
Oct 28, 2016 08:11 PM
Jeff1904
Jun 5, 2016 05:00 PM
PopoFormula
Oct 12, 2015 04:19 PM
canuck94z28
Aug 19, 2015 05:50 PM
