Turbo Experts in here please
Old Jun 20, 2006 | 07:47 PM
ChrisUlrich's Avatar
Moving 72lbs per minute... that should support 700whp right?
49lbs per minute supports 460whp.
What is the exact formula for that? How does this work? Can anyone help me out here?
The benchmarks are used on SRT4 motors just incase that's a question.
Old Jun 20, 2006 | 08:19 PM
Kevin Blown 95 TA's Avatar
Re: Turbo Experts in here please
You know of a 700 whp SRT4?
Old Jun 20, 2006 | 08:44 PM
mn_vette's Avatar
The rough equation is 100 hp for every 10 lb/min of air moved. The exact numbers are widely dependent on humidity and temperature.
Old Jun 20, 2006 | 09:04 PM
There's a couple... yea
Old Jun 20, 2006 | 10:10 PM
That's a wild amount of power for a little car like that.
Old Jun 21, 2006 | 03:21 PM
97WS6SCharged's Avatar
You've never seen some of the ecotech drag cars making 1000+ hp?
http://www.thecarconnection.com/Enth...247.A5482.html
Old Jun 21, 2006 | 06:40 PM
Maybe I'll build a sunfire convertible with a 1000 hp ecotech engine...
Old Jun 21, 2006 | 07:23 PM
Only if you post a vid of the boost gauge passing 40 psi.
Old Jun 23, 2006 | 09:20 AM
blackztpi's Avatar
720 hp has to suck on FWD. get those babies spinning and there goes your steering...not to mention torque steer. hot damn
Old Jun 23, 2006 | 11:25 AM
Zigroid's Avatar
it depends on engine variables. check here:
http://www.turbobygarrett.com/turbob...o_tech103.html
scroll down to where you see:
theres a good equation to figure it out.
Wa = Airflow in lb/min
HP = horsepower
A/F = air/fuel ratio
BSFC/60 = brake specific fuel consumption ÷ 60 (to convert from hours to minutes)
for a 720 horsepower engine:
Wa = 720(horsepower) * 12(air/fuel ratio) * .55/60 (BSFC/60)
that comes out to 79.2 lbs/hour.
95blkss
Sep 22, 2015 03:18 PM
cmsmith
Sep 14, 2015 09:09 PM
NewsBot
Sep 14, 2015 02:02 AM
sleeperZ96BT
Sep 10, 2015 08:01 AM
LeftoverChinese
Jul 23, 2015 03:57 PM
