Turbo Kit done, with Forward headers!!!
Old May 30, 2006 | 03:05 PM
viper03af's Avatar
can't wait
Old May 30, 2006 | 03:31 PM
BADST95's Avatar
Talking Re: Turbo Kit done, with Forward headers!!!
Does anyone make an aftermarket intake manifold for the 3800 V6?
Old May 30, 2006 | 03:39 PM
viper03af's Avatar
nope its perfect the way it is no troulbes with some getting more air then others..... i have made over 450 RWHP and numbers on other cars are up to 475 RWHP......... not needed
mine is stock... simpel P&P will do fine
Old May 30, 2006 | 03:49 PM
BADST95's Avatar
Thumbs up Re: Turbo Kit done, with Forward headers!!!
Well... the set up that I am talking about is probably going to make 600 to 700 rwhp.
Old May 30, 2006 | 04:52 PM
viper03af's Avatar
i don't know of any intake that can add 300 RWHP
lol it will support 9's in ported form
Old May 30, 2006 | 05:19 PM
BADST95's Avatar
Smile Re: Turbo Kit done, with Forward headers!!!
Grrr. I never said that it would add 300 rwhp. A better intake manifold will give more horsepower and torque throughout the rpm range. It's just not all about peak. Not to mention that the stock intake will be a restriction. Apparently the stock intake is the only thing out there.
Old May 30, 2006 | 06:28 PM
viper03af's Avatar
i know i was kidding you
but really porting it make plenty of power so why spend all the money..... ??? i would rahter have a trans brake
Old May 30, 2006 | 08:02 PM
viper03af's Avatar
Originally Posted by mgray
If you are thinking about making 600 to 700 rwhp with the V6 - and want to have a broad power curve- you should be much more concerned with things other than an off-the-shelf "better intake manifold."
Start thinking custom?
these wrong wheel drive guys use the stocker, just ported and its working just fine for them
http://www.3800pro.com/lists/fwdquarter.html
i dont see how custom is need... not unless you want like 8's
Old May 30, 2006 | 09:10 PM
viper03af's Avatar
I wasn't referring to a sheetmetal intake, necessarily. My point was that there is much more to think about other than the manifold for his or her goals; by no means do I assume he or she has neglected to identify the "much more." However, while we are on the topic, do you not consider porting a manifold "custom?"
To hold to a standard of denotation and thus ease of reference, this is taken from http://dictionary.reference.com/search?q=custom
adj.
Made to order.
Specializing in the making or selling of made-to-order goods: a custom tailor.
no i consider a custom manifold wasted mony that could be spent else ware in the car. makinf it faster... like a TQ arm, drag lights and 12 bolt
i'm not saying it is never needed im jsut saying unless your trying to run freaking 8's it work just fine stock for over 500 RWHP and P&P 600-700 RWHP
you will max these heads before you max the intank or TB
Old May 30, 2006 | 09:44 PM
BADST95's Avatar
Start? Everything about this set up is custom. The engine was built for boost. A custom fabricated twin turbo set up is being made as I speak. A special order went into PA Racing for a k-member. Big Stuff 3 is the engine management. And all of this is being done while retaining the A/C and all power accessories. The transmission will be built to handle the power. A 12 bolt or 9 inch rear end will eventually find it's place as the rear end of choice.
So yeah... the stock intake manifold might find it's way to the garbage can.
Old May 30, 2006 | 09:54 PM
viper03af's Avatar
what would that be ? is it a Seires II?
Old May 30, 2006 | 10:17 PM
BADST95's Avatar
2000 Camaro V6.
Old May 31, 2006 | 08:16 AM
Tiago's Avatar
he must be talking about that one girl's car
Old Jun 1, 2006 | 05:25 AM
5.0THIS's Avatar
So is this another world famous Tiago kit with no downpipe or provision for one?
Old Jun 1, 2006 | 07:44 AM
Tiago's Avatar
the turbo shown is not the real turbo for the kit, so the DP couldn't be bolted on i.e. 4 bolt donut vs vband
