catch can
Old Jun 8, 2006 | 10:06 PM
ss97dml's Avatar
catch can
where do i put the catch can? my pcv valve is ran to a small k+n filter right by my blower intake filter. i have breathers on both my valve covers and oil smoke that comes through them and out my hood when i city drive.will the catch can help to get rid of the smoking? if you put deutsh filters in your valve covers,do you run the line that comes off them somewhere?
Old Jun 9, 2006 | 07:45 AM
ss97dml's Avatar
Re: catch can
ANYONE
Old Jun 9, 2006 | 07:56 AM
Kevin Blown 95 TA's Avatar
Re: catch can
This belongs in the forced induction section, and it has been gone over a lot before so you can find a lot of info by doing a search, but here is a summary.
What most find works is to run the PVC valve to a check valve (Brake booster type) then to the throttle body. Then run a breather hose from the valve cover to a oil/air separator of some sort and run a line from that to the intake tube before the blower. If you still need a breather, then add a breather.
95craz28
11
Sep 12, 2015 07:47 AM
RX Speed Works
Sep 11, 2015 03:31 PM
RX Speed Works
Aug 11, 2015 11:16 PM
realistyc
Jul 28, 2015 07:32 PM
RX Speed Works
Jul 24, 2015 02:25 PM
