weird wideband readings and spool problems
how the hell am i suppose to tune this crap
notice the WB reading spiking like that it not really lean plugs and exhuast points to rich
now one of the next run.......(good but that one little spike)
now onto my low 60 foot times
notice here this is my best 60 and best 1/8 mile log (yelllow is maf reading
also notice the WB readings are better
now notice this one (i have many like it) (look at the yellow for the maf reading)
see the differance????
i looked in the excel file........ on my 7.6 runs and many others it took almost exalcy 1 second every time to max the maf.....
now the new logs are all 2-2.5 seconds
WTF
WTF
Re: weird wideband readings and spool problems
I don' tknow what software you're using, but you might want to set it to average the samples so you can see what's going on.
If you're detonating by any chance, it will play hell with your mixture readings.
its HP tuners
i tried using the average thing and it seems close, but then it still a "high" average and i add to much fuel and it goes rich like the one run was
any other info
www.turbov6camaro.com/holttune << all my scans the 7.6 is my best 60 and best 1/8 mile form a few weeks ago
Originally Posted by engineermike
An intermittent miss will cause lean spikes in the WBO2. If a cylinder misses, it pumps unburned air into the exhaust system.
also i'm using a LC1 for my WBO2
Magenta_Hearts
Mar 5, 2015 07:01 AM
z28projects4ever
9
Jul 16, 2002 07:48 PM
