Cam
Old Jun 2, 2006 | 06:13 PM
95TAMaddog's Avatar
Question Cam
In your opinon what is the best cam you can get for a blower car?
Old Jun 6, 2006 | 10:28 AM
RealQuick's Avatar
Re: Cam
I felt bad nobody chimed in...
If you want answers to questions from these guys, then you need to be detailed. The cam depends on your goals...what you want to use the ca for, what power level, info on what heads, etc...
Old Jun 6, 2006 | 12:41 PM
boosted-lt1's Avatar
Re: Cam
In your opinon
I like my COMP 218-230-114 but might go bigger with the next engine. It does pull 6th at 70mph with 3.42:1 pretty nice.
-Scott.
Old Jun 6, 2006 | 07:15 PM
ronbros's Avatar
Re: Cam
I would go for 208-220-118 for the street. THX RON
Old Jun 6, 2006 | 08:39 PM
joe-96z1le's Avatar
Re: Cam
With so many variables in an engine and desired driveability I lean towards a custom design cam rather than an off-the-shelf grind. But most people seem to use a cam with about 10-12 degrees more duration on the exhaust side, ground on a 112 to 114 LSA +4 deg adv.
rideordie
Nov 5, 2019 04:52 PM
alex5366
Feb 17, 2015 08:12 PM
Queens94z28
Dec 20, 2014 09:11 PM
Queens94z28
Nov 20, 2014 06:03 PM
