Need Fan help
Old Jun 20, 2006 | 10:01 PM
Gearhead6s's Avatar
Need Fan help
I have a modified the core support, the almost standard way, by cutting the support and standing an aluminum Griffin radiator vertical. My turbo and wastegate sit inchs from the radiator on the engine side so there is no way to get a fan in there. I have been screwing with Flex-a-lite PN 230 dual fan setup for about 2 hours tonight and there is just no way to get it to fit my setup. My lower rad. hose is to close to the turbo downpipe to push the rad. any further back, I have already had the lower outlet raised as high as I care to go to make more clearnace. I can't squezze this fan between it and the new core support bar or between the headlights. I need suggestions and possibly part numbers for a pusher fan setup to fit in the 22"x15" space that i have. Need to decently cool a potential 1000hp turbo LT1, water wetter and 160* t-stat will also help. Any and all help is needed and appreciated.
Formula Steve
Sep 19, 2023 08:31 AM
93 RedBird
Nov 15, 2015 08:24 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
Pwilson59
Sep 3, 2015 08:47 PM
4586
Aug 24, 2015 11:04 PM
