Need pics of installed P1SC with 2 core intercooler
Old May 25, 2006 | 08:43 PM
Mizz96Z28's Avatar
I did a search and came up empty handed. I really need some pics of the whole 8 PSI P1SC kit with 2 core intercooler installed on a 1993-1997 f-body from under the car. The directions absolutely SUCK for this kit, and I'm trying to set up the inlet tubing with the filter under the car the way I think they are saying in the directions but there's no way it'll work, I think the page with the directions for the inlet are actually for the twin intercooler setup because it says something about the driver's side intercooler when I only have 1. I would really like to cause physical harm to whoever wrote these directions but will settle for install pics for the time being. Thanks
Myles
Old May 26, 2006 | 05:24 PM
Mizz96Z28's Avatar
Re: Need pics of installed P1SC with 2 core intercooler
Ttt
Old May 30, 2006 | 12:24 PM
1SlowFormula's Avatar
No pics, but this thread has some good info and tips...
Old May 30, 2006 | 02:18 PM
Ponyhntr's Avatar
Do you a new kit, with the new inlet, or is it an older kit?? Here's a pic of the new inlet on my car:
Old May 30, 2006 | 05:15 PM
Mizz96Z28's Avatar
Ponyhntr, it looks like you have the high flow twin intercooler setup, mine is only the one intercooler mounted directly in front of the motor on the bottom so I ended up just putting the filter directly on the newer styled inlet elbow, cos with the 90 degree rubber elbow and the 45 degree aluminum elbow, there's no way that **** was going to fit, too much intercooler stuff in the way. I see you have a 96 Z28 and you're using both your barbs on the inlet, whats the 2nd for? I know the 1st is for the optispark vacuum line but the 2nd I ended up capping off. In the manual it says something about 97 f-bodies using both barbs but now that I see your 96 with both used I'm confused. thanks
Myles
Old May 30, 2006 | 08:58 PM
Ponyhntr's Avatar
Myles
Both of the vacuum lines are comming from the opti... one from the cap, the other from the main body.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Burn_Out
Aug 18, 2002 08:49 AM
Makaveli
Jul 29, 2002 01:52 PM
