Whats everyone using for plug wires?
Old May 14, 2006 | 01:23 PM
CALL911's Avatar
Just curious as to of the type/brand of plug wires people are using with their forced induction cars? I currently have the MSD 8.5 mm wires, but they are a little worn, and was considering changing the wires before the blower goes in.
Old May 14, 2006 | 01:34 PM
DarkHorse's Avatar
Re: Whats everyone using for plug wires?
I just switched from the MSD 8.5's to the OTVC kit with Taylor wires. So far I like them - they can easily be routed away from the headers.
My MSD's were great too - but clearly the routing is better with the OTVC kit.
Old May 14, 2006 | 01:36 PM
CALL911's Avatar
I am probably an idiot here but what does OTVC stand for?
Old May 14, 2006 | 01:38 PM
DarkHorse's Avatar
Over the valve cover
Old May 14, 2006 | 01:53 PM
CALL911's Avatar
As figured earlier, yeah I am an idiot. Thanks. Those look pretty sweet. Do you know will they fit on the LT4 style valve covers? Where can I find the MSD OTVC wires and how much will they cost? I have seen the Taylors OTVC go for about $115.
Old May 14, 2006 | 03:54 PM
SiDeWaYZz28's Avatar
im usng the taylor otvc wire setup..im loving it so far no burnt up wire from the headers no more
Old May 14, 2006 | 04:09 PM
Mizz96Z28's Avatar
Not to hijack the thread but Darkhorse, how did you route the passenger side wires? I have a set of the Taylors coming in Monday and was trying to see if there was a better way to route the passenger side wires instead of going behind the powersteering pump and up in front of the big *** aluminum bracket for the PS and AC pumps. I came up with a couple different ways but was just curious to how someone else tried doing it. Thanks
Myles
Old May 14, 2006 | 09:23 PM
DarkHorse's Avatar
I went behind the PS pump - tight fit but they made it. Was tougher routing around the SC head unit.
Old May 14, 2006 | 10:01 PM
97WS6Pilot's Avatar
I'm using Accel 8.8 300+. The delteq radiator mount runs the wires up under the headers through the engine mounts.
Old May 15, 2006 | 12:48 AM
Flip94ta's Avatar
I have used a few sets of the MSD wires after trying a few others, I am very happy with MSDs. I espically like the click that lets you know that they are properly seated.
Old May 15, 2006 | 09:18 AM
CALL911's Avatar
Thanks for all the info. I just ordered a set of OTVC Taylors from Thunder Racing. If anyone has any more pics of thier set up that would also be helpfull. More replies welcomed.
Old May 16, 2006 | 12:44 PM
bkrepindy's Avatar
Another vote for Accel 8.8mm 300+ Race Wires.
Old May 16, 2006 | 01:21 PM
evilundisguised's Avatar
Another vote for the Taylors. They were kind of a pain because I crimped on the Opti boots after routing the wires, but still easier than the stock wire routing I figure. Plus they looks pretty cool and I haven't had any get torched by header primaries.
Old May 16, 2006 | 10:08 PM
leadfoot94's Avatar
Accel Extreme 9000s run through stock location. No more need for the aluminum heat shields on the boots.
Old May 17, 2006 | 09:17 AM
myslowcamaro's Avatar
i know someone that sells spark plug wire sleeves. good up to 1200 degrees. many colors pm if interested. they have heat wrap too
