big fuel problems!!!!!!!!!! help
Old May 1, 2006 | 06:57 PM
95 N2OT/A's Avatar
i just put my 355 turbo setup in my car
it has 42lb injectors and was tuned for them before i pulled the motor out of the other car it was in
i put it in my 95 trans am and now it is running way rich i mean there is a river of fuel comming out of my tail pipe
any suggestions on what it could be?
is there any sensors that could cause this?
i'm located in mansfield tx if your close and willing to take a look at it i'll repay you in beer
please be something cheap i'm out of money!!!!!!!!!!
thanks
robbie
Old May 1, 2006 | 10:03 PM
roguedriver's Avatar
Re: big fuel problems!!!!!!!!!! help
What kind of car was the motor previously in?
Ken R.
Old May 1, 2006 | 11:52 PM
NC-LT1's Avatar
had the same thing happen on a car.. it is one of two things.. and injector is hung open or the drivers in the PCM are fried and they are holding injectors open.. in my case it was on the drivers side and just as described.. raw unburned fuel in liquid form was pumping steady from the header.... noid light will tell the tale if the PCM is functioning in which case the light will blink with each pulse.. if it stays lit.. it is the PCM.. if it blinks.. it is a bad injector.. my money is on the PCM1
Chris
Old May 2, 2006 | 09:11 AM
Sean94Z's Avatar
Yep, sure does sound like an injector is hung open .. Gotta test those first ..
--Sean
RUENUF
Mar 13, 2016 03:39 PM
Scottyboy
Feb 11, 2015 10:28 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
FIREBIRDMARK1
Jan 7, 2015 03:36 PM
CARiD
Dec 26, 2014 04:20 AM
