quick ? quick answer. procharger users please post
Old Apr 20, 2006 | 08:35 AM
hulettsz28's Avatar
What do you currently idle at with your p600b, or, what SHOULD i idle at with mine? Mods are in my sig. Im afraid mine is a little low, it is below 1000. Thanks
Old Apr 20, 2006 | 08:29 PM
Pullngz's Avatar
Re: quick ? quick answer. procharger users please post
About 825-850 according to the scanmaster.
Mike
Old Apr 21, 2006 | 09:06 AM
Ponyhntr's Avatar
The blower isn't going to effect idle at all. My car idles at 850 with a cc306 cam, and D1SC.
A stock car will idle somewhere around 750 rpm.
Old Apr 22, 2006 | 08:52 PM
Procharged94Lt1's Avatar
The stock computer sets the idle slightly higher before it warms up, once its warm you should be right about 800-850 range. Shouldn't be a problem and the blower shouldn't have affected it at all.
The tach might be off too- my laptop says idle is at 850 while the tach is reading closer to a grand- keep that in mind.
Old Apr 25, 2006 | 07:39 PM
NHRA's Avatar
My P600B on my LT1 impala idles at 950 by the tach, but reads 850 on the laptop.
Old Apr 28, 2006 | 02:14 AM
Sparkz28ss's Avatar
800-850rpm LT4 hot cam and p600b
Old Apr 28, 2006 | 07:34 AM
Sean94Z's Avatar
Your car may idle higher because you are now forcing air at the throttle body. If the IAC motor is already closed all the way then your idle will go higher because of the extra air that is being forced past the throttle blades. We adjust that on aftermarket throttlebodies with a set screw.
BTW, mine idles at 1000 RPM... I have adjusted my throttle body though..
D1SC383LT4
Jan 1, 2016 01:56 PM
Jlo
Feb 3, 2015 09:41 PM
SpeedJunkee
Jan 27, 2015 10:02 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
