STS Users
Old May 16, 2006 | 04:56 AM
97SS4KS's Avatar
STS Users
Hey Guys,
Having a problem that happened all of a sudden. The blue elbow going to the throttle boddy keeps popping off under boost (8lbs). I get half way down the track and it pops off. I do make sure that the clamp is on tight but still keeps popping off. any of you all experience this?
Old May 16, 2006 | 11:03 AM
383Z4ME's Avatar
Re: STS Users
I kept having the air filter pull away from the throttle body on my '98. It turned out that putting a new trans mount fixed the problem. Car engine was dropping in rear and rising in front more than it should.
Old May 16, 2006 | 11:59 AM
Sean94Z's Avatar
Re: STS Users
Try putting on 2 clamps or get a t-bolt clamp.
Old May 16, 2006 | 12:33 PM
97SS4KS's Avatar
Re: STS Users
Thank you guys for the insight
Old May 16, 2006 | 05:50 PM
94irocz's Avatar
Re: STS Users
have you dyno'd it any higher then 8lbs? any idea what your motor made on motor alone with no boost? sorry for the high jack i'm just trying to see where i'd be at if i went the sts route.
Old May 16, 2006 | 10:54 PM
97SS4KS's Avatar
Re: STS Users
Sorry did not make a dyno run without boost.
2QUIK6
Sep 17, 2016 02:31 PM
Henson071
Sep 18, 2015 04:01 PM
speedracer1280
Sep 8, 2015 06:12 AM
maverickmk
Sep 1, 2015 09:17 PM
Henson071
Aug 4, 2015 09:32 AM
