P1SC guys inside please...
Old Jun 21, 2006 | 08:51 PM
steve10358's Avatar
3rd Gen Tech Moderator
Real Quick- For those of you that had the 6psi Procharger P1SC kit and have since upgraded pulleys to the 8 or 9 lb setup, what size did you go with?
I'm talking stock to near stock motors/heads and near stock RPM levels. I understand boost is resistance, blah blah. I just need someone to come out and tell me how they got to 9pounds without the typically evasive answers.
Thank you!
Steve
Old Jun 21, 2006 | 09:27 PM
markinkc69z's Avatar
Re: P1SC guys inside please...
Steve, on a small block with the P1SC its about 1 psi per .100"-.125" change in pulley diameter. As the kits are put together with your particular setup and elevation in mind the actual diameter required to get there will vary between cars.
Hope that helps.
In case that sounds evasive you'll want to run a pulley .300-.400" smaller than what you have now if you're currently getting 6 psi.
Old Jun 22, 2006 | 11:14 PM
Kraest's Avatar
Retired
How about stickin a cam in that thing and waking up the blower?
Old Jun 23, 2006 | 09:42 PM
steve10358's Avatar
Mark, thats not evasive- I appreciate your answer!
Kraest, I am putting the new shortblock in, and while I save for the heads and a suitable cam... I wanted more boost and and more fuel while I do that. Thanks for the suggestion though.
S
Magenta_Hearts
Mar 25, 2015 10:24 AM
cmsmith
Mar 14, 2015 03:48 PM
carl.froehlich
Mar 13, 2015 12:38 AM
squarehead
Nov 21, 2014 08:02 PM
Red97LT1
Aug 7, 2002 05:45 PM
