9 or 10 lbs
Old May 4, 2006 | 09:14 PM
95TAMaddog's Avatar
9 or 10 lbs
I need to find out what combination of crank and blower pulleys to run 9 or 10 lbs. I have stock crank and 6 lb blower pulleys. I have a vortech s-trim supercharger. Thanks in advance.
Old May 5, 2006 | 09:42 AM
OBE1 95Z28's Avatar
Re: 9 or 10 lbs
The stock Vortech 3.3" pulley and a 7" crank pulley will net you 9 psi on a stock motor with the flexible inlet tubing (dryer ducting) or 10 psi if your running a solid intake tube (Brad Brand tube).
93 RedBird
Nov 15, 2015 08:24 AM
football4life
Oct 4, 2015 07:48 AM
1bad427ls1
Sep 23, 2015 01:12 AM
karpetcm
Aug 14, 2015 03:02 PM
