Help Procharger Question
I have an 02 SS and I am in the process of buying a procharger kit and I was told I need to buy a new harmonic balancer, is this true? If so, why? I plan on running 8lbs - 10lbs of boost.
Re: Help Procharger Question
If you want to do the kit right and go with the 8 rib drive system, the yes, you need to change your balancer. If you want to take the cheap way out (which you'll regret later on down the road), then you can keep the factory balancer and just run the 6 rib drive system.
Originally Posted by mzgp5x
Try Jegs. I got 1 from there. LT1 app. 383-D1
