Lt1 383 Crank for 6" rods?What cam too?
Hey guys Im building a 383ci for my new turbo setup and Im looking for a forged crank that will work with 6" rods.All of the ones I see listed in summit are for 5.7" rods.
Im looking for something like eagle or a scat crank....not one of these 1,100 dollar suckers.
Also I would like some ideas on a nasty turbo cam and strong set of springs for the 383 with LE3 heads.
looking for 750rwhp with a PTK gt76 kit...
thanks for the help
thanks for the help
Re: Lt1 383 Crank for 6" rods?What cam too?
The 5.7" cammed cranks will work with 6" rods, but balancing may require more heavy metal. You just might have to ask for a crank cammed for 6" rods to get more metal ont he counterweights. It might have more to do with internally balancing an engine which originally came with an externally balanced flexplate, but I'm no expert on how muchh is too much or not enough.
As above except for one thing. In GENERAL, a long rod piston/rod combo is LIGHTER than a combo for a shorter rod. Of course, any given model crank may not reflect this. But as stated, you can use a longer rod for with a crank listed for a 5.7" rod. You can also use a shorter rod, but maching the counterweights (or the pistons) will be needed.
BTW: the Callies Dragonslayer and the Lunati Sledgehammer series are moderate price high quality domestic 4340 forgings that I personally much prefer to the only slightly less expensive Eagle cranks that many people use. Either can be had as part of a complete, balanced RA, which is a big convenience and often a money saver when assembling an engine.
Rich
Rich
That's what we ended up going with for my motor. A Lunati Sledgehammer for a 5.7" rod as we were originally going to use a 5.7" rod, but due to developments unforseen we're moving to a Lunati Pro-Mod 6" rod, and my engine builder says it's no big deal.
well I have the pistons and rods so all I need to get the bottom end done is a crank
What about a cam ?
anyonr got a good place to start?
What about a cam ?
Callies also has the Compstar line of cranks, which retail for around $700.
http://www.compstarcomponents.com
You can get them through Victory Racing Engines
Originally Posted by Sparkz28ss
What about a cam ?
Originally Posted by engineermike
Opinions vary wildly on this. You pretty much can't go wrong with something in the 225/225-114 range. We just made 930 hp and 1050 ft-lb with a 377, T-76GTS, 18 psi boost, on a 230/230-114 cam.
I'm with ya Mike, I did single pattern cams for a good portion of my forced induction stuff. Always make great power.
As for a crank, I think the compstar would be a good option. They have two 3.750 cranks, one cut for 5.850 and another for 5.700.
-Nick
location of the pin and the compression distance will be adjusted accordingly to work with whatever rod and crank combo you have.
I'm not sure I follow what you are asking?
well....I have the rods , its not like I cant get another set....if I m waisting my time with the 6: rods tha tI can snag some 5.7s....no biggie
