PDA
View Full Version : Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 [23] 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69
  1. 4L60E problem
  2. Pinion Nut Torque
  3. Turbo 350 no first gear
  4. can tranny take 360rwhp?
  5. clutch install
  6. why a 700r4 conveter wont work with 4l60e
  7. Gear Grind
  8. NEED HELP...rear end paddle question
  9. POSI Question
  10. How to disconnect line from slave cylinder?
  11. t56 conversion impossible with long-tube headers??
  12. t-56 swap
  13. t5 transmission questions
  14. Clutch / Trans. making wierd noise / vibration
  15. does this tranny cooler look
  16. Is it done?
  17. tranny issue
  18. your thoughts lt1 T56 4.22's
  19. need a tranmission
  20. Will a shifter for a 700R4 work for my 4L60E?
  21. Tranny knock/rattle? HELP!!
  22. 10 bolt with different axels handles more power?
  23. Driveshaft strap bolt torque spec
  24. new gears got whine
  25. HELP!! 2001 Z28 shakes violently!!!
  26. Strange Dana S60 rear posi selection?
  27. Please help with stall recommendations for 383 daily driver LE2 heads/cam
  28. Whatcha Ma Call IT?
  29. '96 4 channel rear end fit on '02?
  30. LT 4 Clutch, what do you think
  31. clutch replacement need some info
  32. A4 gear choice
  33. Strange Seamless Chrome Moly DS vs Denny's Nitrous Ready DS
  34. T56 Clutch Fork issue
  35. Got My New Ram HD PowerGrip Clutch
  36. Stripped bellhousing bolt A4 HELP !!!
  37. Anybody with Yank 3200 or Yank 3600? Need some advice...
  38. T56 Install problem - Won't go on all the way
  39. clutch
  40. Anyone with Yank 3200 or Yank 3600 ?? Need some advice...
  41. ring and pinion question
  42. how do i disable traction control
  43. what gears!!?
  44. noise anyone else have and fix?
  45. th400
  46. zexel or auburn?
  47. what works in a 95z a4
  48. Ok still doing alittle wiring on t56 swap
  49. Aubern posi problem
  50. Throw-out bearing lube...
  51. Best way to drain 4l60E?
  52. stall from a 4l60e work in a 700r4??
  53. 3 series Carrier
  54. 3rd gen rear in a 4th gen
  55. M6 Conversion
  56. Yank PT4000 = totally streetable
  57. Questions about bolting torque converter to flywheel
  58. locker vs. auburn/torsen posi
  59. T56 jumping out of 2nd?
  60. transmision
  61. T56 Interchangability
  62. Grand Prix Transmission whine, please help if you can.
  63. hey, 4th gen question
  64. Tremec TR6060
  65. Bouncing off rev limiter need help
  66. Weird non shifting problem COME IN AND SEE
  67. Vibration at 4K after clutch install
  68. Learning to build a 4l60e
  69. Redline Transmission fluid,OK?
  70. Royal Purple Gear Oil?
  71. Thoughts on Spec Stage 3
  72. how many spline rear end in a 93z28
  73. Need T-56 parts
  74. clutch fork problem
  75. Going 65 my buddy is 3 1/2 MPH faster!
  76. M6 fluid check?
  77. Stall speed vs. Shift Points??
  78. Does anybody have anything good to say about TCI
  79. $500 for gear install??
  80. Transmission Service at 80K Miles?
  81. What gears do I have exactly?
  82. recommend a converter
  83. Differential on its way out..Question
  84. GM 3.73's for 10m bolt
  85. How much fluid so I need for a 4L60E fluid /filter change?
  86. t-56 to th350 swap ds length
  87. Good tranny specialist
  88. Anybody rebuild your own t56? Or reverse synchro/fork replacement?
  89. Post your A4 to M6 conversion experience
  90. one question after reading stickies
  91. TNA Short Stick
  92. Need help diagnosing 4l60e problem
  93. Pressure plate bolts and flywheel bolts p/n please
  94. Need some help?
  95. New Moser M9
  96. Replacement transmission line options? Part #'s?
  97. gear in my A4
  98. Popping/Clunking when stopped/stopping PLEASE HELP!!
  99. so i've decided...
  100. Clutch Question
  101. Received my CPT transmission and my Yank PT4000
  102. converter shudder
  103. shift points w/ dyno tune??
  104. FIXED: Vibration above 4000 grand
  105. tranny
  106. Got my Fuddle Racing Stall today!
  107. zexel torsen
  108. Axle bearings wont move
  109. torque converter issue after dragstrip
  110. What clutch is best?
  111. what series do I have?
  112. lost all atf
  113. Transmission Noise (M6)
  114. Transmission Noise (M6)
  115. 400hp/M6 guys
  116. TRanny Problems
  117. stall and gears
  118. M6 bellhousing pattern?
  119. B&M shfit improver install
  120. what gears with GM847
  121. Are my auto shifts normal?
  122. Car grinds at idle in gear,,,,,why?
  123. gas milege
  124. i need to put in new gears
  125. Transmission, Clutch, or something else?
  126. Rear End Fluid
  127. transmission??
  128. My M6 car doesn't want to go in reverse? Suggestions??
  129. 383 cc306 with 4l60e 3500tci 3.73 lockup shuter,
  130. Rebuilding a street twin?
  131. 383 folks with 3.73 or 3.91 gears?
  132. how hard to swap t56 to th350 or 4L60E
  133. Replacement cooler line fittings & re-flare of lines (4L60E)
  134. TCI Saturday Night Special converter
  135. Misc bracket
  136. Transmission lines
  137. Issues??
  138. wiring questions on t56 swap!
  139. glove box sticker 1995 T/A
  140. rear end gearing help
  141. auto only works in revers
  142. Corvette-Fbody T56 flywheel interchangable?
  143. 4.10 & M6 in 1/4
  144. stahl
  145. Non-Fbody Trans Question?
  146. What is chattering???
  147. t5 question....
  148. Converter question
  149. torque converter
  150. Budget 9in..
  151. A4 Gears
  152. moser 12 bolt ?'s
  153. trans swap
  154. 4l80e shift controller
  155. found old gears
  156. trans temp question..
  157. short stick for pro 5.0
  158. labor price for Strange 12-bolt install
  159. 12-bolt w/spool
  160. will this work on my car
  161. tranny issue on 2001 z28
  162. Transgo-shift kit questions.
  163. More A4 trans problems...
  164. tranny type...
  165. PLease help, tranny messin up....
  166. T56 Rebuild: local or T56rebuilds.com
  167. Mcleod single disk good for 400+ hp
  168. v6 -> v8 swap auto->manual
  169. Which Converter? (Under $700)
  170. Clutch problems i need help!plz
  171. how much can this 9" handle?
  172. How big is yours? Converter
  173. Will it hold!?!?
  174. Strange 12 bolt
  175. 9" axle pinion offset?
  176. SBC/BBC Flywheel ?'s
  177. stall installed
  178. best shift kit
  179. Trans removal...
  180. Strange rear axles
  181. Help diagnose
  182. 2500 stall
  183. Powerglide
  184. 4l60e Pump issue
  185. tranny temp
  186. How much $?
  187. Non LT1 Trans cooler question
  188. Skip Ship?????
  189. How much?
  190. Built 4l60e or TH350
  191. 10 bolt build up??? vs dana s60
  192. What fluid 88 T5 WC atf 3 syn or a synchromesh
  193. 10 bolt housing v6/v8 the same?
  194. Where can i find gears for my Aussie 9 Bolt Rear?
  195. stock trans question
  196. rear differential series?
  197. Is it possible to mate an LS1 tranny to an LT1?
  198. Need info to install 700r4 in 69 Camaro
  199. t56 swap question(cable)
  200. 10 bolt ?
  201. HElp tranny problems....
  202. SWRacecars.com
  203. Anyone have a "how too" on rear gear change?
  204. AC Delco clutch, good or bad?!
  205. Washer for torque arm?
  206. 96 LT1 AutoTrans Rebuild?
  207. noise from new clutch install
  208. Auto Trans Rebulid
  209. LT1 or LS1 T-56 tranny crossmember?
  210. BMR torque arm relocation bracket
  211. 4.10 gears??
  212. Best Converter Brand?
  213. Are LS1 and LT1 rearends the same??
  214. What gear (rear end)
  215. LS1 swap into a 94 Z28?
  216. ring and pinion broke loose
  217. I know it's been asked, but the T5...
  218. Is my Ring and Pinion done for?
  219. Can I change a steering rack in my garage (home)?
  220. Clutch pedal gone. Need help ASAP PLEASE!!!
  221. What flex plate???
  222. 3:73' s with auto
  223. Who knows there E40D's
  224. Stop Leak Additives
  225. Few questions about this tranny.
  226. aftermarket shifter in 4l60e
  227. rear end yoke?
  228. T-56 jumps out of reverse
  229. rear gears
  230. T56 parts
  231. Spec III Clutch Help
  232. need help guys...(clutch)
  233. Poly tranny mount with or without the plate ???
  234. 3.73 Installation Checklist.
  235. Turbo 400 tale shaft
  236. transmission help
  237. Clutch engagement problems
  238. Automatic to Manual?
  239. Just ordered RAM Powergrip
  240. 700R4 shift kit install Q
  241. 4L60E on the way to Frank/CPT!
  242. 3rd gen rear into 4th gen
  243. Weird vibration on decel after the track last night
  244. 700-r4 shift kit selection
  245. Replacing tranny what do I need?
  246. 4L60E from a '94 Silverado?
  247. No Overdrive
  248. Textrailia review(30 miles). M6 question. This clutch is cool!
  249. What Gears Do I Have???
  250. 4 series axles on a 3 series
