Is it done?
Old Mar 12, 2007 | 12:28 PM
chris8835's Avatar
Is it done?
Hello,
I have a 95 Z28 with about 48,000 on it as of now and I think the tranny might be done. It doesnt shift into second at WOT or any other gear anymore, all it does now is bounce off the rev limiter till I let off. It is also a little hesitant to shift gears when driving normal, and when switching from Reverse to Drive. I do my fair share of racing but for the most part I drive it very civilized, because I feared of something like this happening. this slipping just started right after I replaced my broken tranny mount, I took it for a test drive got on it, and thats when this all started. Is there anything I can do, or is this tranny done? Any help would be appreciated.
Old Mar 12, 2007 | 12:56 PM
MyShibbyZ28's Avatar
Mine did the exact same thing. The band started to slip, and eventually broke. It's done.
Old Mar 12, 2007 | 04:34 PM
12SCNDZ's Avatar
As long as the fluid level is where it should be, you're most likely seeing early signs of 2-4 band failure.
Frank
CPT
Old Mar 12, 2007 | 09:09 PM
Frank
CPT
Thats the band that snapped on mine. First it was a lerching shift, then wouldn't shift at all WOT, then didnt shift period. It would go straight from 1st to 3rd, and never 2nd or 4th.
