rear differential series?
Old Feb 9, 2007 | 03:20 PM
leanjay's Avatar
my 97 z28 has the 3.23 axle ratio and the abs brakes,i'm going to to change it over to 3.73 ratio but i'm not sure which series differential i have ? any help would be welcomed!! thanks
Old Feb 9, 2007 | 04:44 PM
If your car left the factory with 3.23 gears (GU5 on the build code tag) is has a 3-series carrier. But you indicate your car has an M6???? The M6's (94-02) only came with 3.42 gears (GU6), also a 3-series. Or did you do an A4->M6 swap?
Only the 2.73 geared A4's (GU2) use the 2-series carrier.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Alien
Jun 27, 2015 01:13 PM
anmar A
May 2, 2015 06:59 PM
QuickSilver02
Apr 7, 2015 11:12 AM
