4l60e Pump issue
Old Feb 11, 2007 | 10:33 PM
mannycamaro's Avatar
From: San Juan Puerto Rico, Look it up it's in the Caribean
4l60e Pump issue
Hi,
I rebuild my transmission and put a new daico converter and a new pump. But when I put back the transmission the car don’t move. I think that not have pressure, so we take off the transmission and the converter and don’t see any oil in the converter. I think the problem is the pump that maybe don’t is the correct one for the 4l60e.
I heard that for this transmission comes two different oils pump is that true ???
Old Feb 12, 2007 | 07:43 PM
12SCNDZ's Avatar
You did remember the filter, right? Did it (filter) fit tight in the boot in the pump?
You didn't break the pump rotor when you installed it, did you? It's pretty common to have someone break a rotor because the converter isn't all the way in. The pressure regulator valve (in the pumnp) didn't blow out did it? Are you sure the pressure regulator is assembled correctly?
There are several pumps for the 4L60E. Early (non PWM), Late '95-'97 PWM with short stator and '98-up LS1 style with long stator. What year is yours?
Frank
CPT
Old Feb 15, 2007 | 01:19 PM
Thankyou !
Thankyou Frank !
HectorM52
Jul 30, 2017 11:46 AM
Scottyboy
Feb 11, 2015 10:28 PM
Jan 5, 2015 07:14 PM
Snoman73
Nov 17, 2014 07:22 PM
Zone
Jul 29, 2002 07:43 PM
