What flex plate???
Old Feb 5, 2007 | 09:40 PM
snakeatinZ's Avatar
What flex plate???
What is a good Flexplate for me to go with? How many teeth does it need??? set up in sig.
Steve
Old Feb 5, 2007 | 09:53 PM
mdacton's Avatar
jegs has a descent one 555-60153
if you just want a stock one let me know....other than that you nd a 153 tooth for 1pc. seal 86-up
Old Feb 6, 2007 | 12:02 PM
12SCNDZ's Avatar
I agree...Jegs has an SFI approved plate for less than a stock one costs.
Frank
CPT
Old Feb 6, 2007 | 03:37 PM
snakeatinZ's Avatar
Cool. That is the one I am going to buy.
Thanks guys,
Steve
Old Mar 6, 2007 | 01:41 PM
snakeatinZ's Avatar
How many bolts do I need to buy from GM? I am going with Part # 14088764.
Thanks,
Steve
Old Mar 6, 2007 | 03:05 PM
mdacton's Avatar
what bolts? its cheaper to get the ARP's anyway
Old Mar 6, 2007 | 03:15 PM
snakeatinZ's Avatar
Flexplate bolts. I searched it and found people are having problems with Arp ones. The head on them is too big and does not fit a socket well???
Steve
Old Mar 6, 2007 | 07:33 PM
The Engineer's Avatar
Steve
Yes, that is correct. The large 12-point heads on the ARP flex-plate bolts do not allow space for the socket between the crank hub lip. Get a new set of OEM (GM) flex-plate bolts. Also, use a thread locker and make sure the flex-plate isn't powder-coated.
WD
Old Mar 6, 2007 | 10:16 PM
mdacton's Avatar
ARP came out with new ones that have smaller heads.
Old Mar 7, 2007 | 05:19 AM
rskrause's Avatar
Moderator
You realize that this is not an LT1 specific piece but is generic? If you have stock rotating assy., you can buy a flexplate that is a simple bolt on as it is already balanced against a stock bob weight. If it's for the combo in your sig, which looks like a non-stock setup, it is going to need to be final balanced. You probably already know this, just pointing it out to those reading who think the piece would be a simple bolt-on.
Rich
Old Mar 7, 2007 | 06:17 AM
snakeatinZ's Avatar
Rich
Rich, whenever you have something to say I am all ears. Over the years you have tought me alot about these cars. My motor has a stock crank, with forged Speed Pro pistons. I need the flexplate for the Machine shop. This weekend they are going to get everthing I have to assemble the long block. oooh happy day!!!!!!
Steve
Old Mar 7, 2007 | 06:38 AM
rskrause's Avatar
Moderator
Steve
Great feeling!
A "generic" flywheel like that will usually have a large balance weight. The machine shop will balance it against your specific assembly by drilling shallow holes in the weight to remove the necessary amount.
Rich
GREEN3112
Feb 10, 2019 09:19 PM
Ericksd
Jan 20, 2016 06:07 PM
95blkss
Sep 22, 2015 03:18 PM
Daluchman1974
Sep 11, 2015 06:12 AM
karpetcm
Aug 14, 2015 03:02 PM
