4 series axles on a 3 series
Old Jan 31, 2007 | 07:10 AM
john-e-boy's Avatar
will axles out of a 4 series rear (with the reluctor rings on the axles) work on a 3 series rear that doesn't have the rings on the axles? My set up has the reluctor inside the housing.
Do I need to change the dust plate inboard of brake disc's or anything?
John
Old Jan 31, 2007 | 09:41 PM
John
Do you mean "will axles out of a 4-channel rear (with the reluctor rings on the axles) work on a 3-channel rear that doesn't have the rings on the axles?"
Or are you looking at something like a 12-bolt, that actually houses a 4-series or a 3-series carrier?
Old Feb 1, 2007 | 05:15 AM
john-e-boy's Avatar
Stock for stock, I have a 3 series rear with a bad axle. I had an option to get a set of 4 series axles and wanted to know if they would work on my 3 series stock rear. Would they fit since they have the reluctor rings on the inside of the flange?
John
2QUIK6
Sep 17, 2016 02:31 PM
Quickss96
Jan 29, 2016 05:56 PM
IndyZman
Oct 22, 2015 02:17 PM
Daluchman1974
Sep 11, 2015 06:12 AM
Catmaigne
Jul 14, 2015 05:17 PM
