Need info to install 700r4 in 69 Camaro
Old Feb 9, 2007 | 12:49 PM
FrankG's Avatar
I'm planning on installing a 700r4 tranny in my 69 Camaro. It has a 350 turbo trans now. What will need changed? Will this trans crossmember work? I have an aftermarket shifter that will work with the 4 speed already so i'm good there. Thanks for any info!!! Frank garbaczs@hotmail.com
Old Feb 9, 2007 | 02:15 PM
mdacton's Avatar
the cross member will need to be modified and the driveshaft will need to be cut down and balanced.
Are you using a luckup converter?
Old Feb 9, 2007 | 02:48 PM
FrankG's Avatar
Yeah i want to use lockup too. Whats the easiest way just run a manual lockup toggle switch? Or does someone sell something for this? How will the crossmember need to be modified?
Old Feb 9, 2007 | 02:51 PM
mdacton's Avatar
the mount is back a little bit. They make a kit so you can hook up the lock-up the right way...I know they have it in summit
I make most trans mounts out of roll bar....you may be able to just cut the mounting tab off the stock one and reweld it, Thats a simple fix either way
Old Feb 9, 2007 | 05:07 PM
12SCNDZ's Avatar
Frank, Do you remember working with someone at Deltrans that used to call you "mushroom head"? Give me a call, and I'll help you with the lock-up deal.
Frank
CPT
302-250-1202
Old Feb 11, 2007 | 08:00 AM
FrankG's Avatar
Yeah i'll give a call. Whens the best time? Frank
Old Feb 11, 2007 | 09:01 AM
12SCNDZ's Avatar
Probably after 6 during the week.
Frank
Old Feb 13, 2007 | 03:10 PM
FrankG's Avatar
Frank's the man!!! I'll be visiting him this week sometime.
Old Feb 13, 2007 | 03:13 PM
mdacton's Avatar
yep, he knows his stuff
Cam's maro
Dec 28, 2014 09:30 AM
bernie1951
Dec 10, 2014 10:03 AM
CaRParts102
Dec 6, 2014 08:45 AM
Dec 4, 2014 11:56 AM
Jul 4, 2005 05:00 PM
