i need to put in new gears
Old Feb 23, 2007 | 12:21 PM
camarokidSS420's Avatar
i just put in a junkyard rear end because my housing was bent and it cam with 273s and out the hole it sux and i have 342s in my old rear end and was wondering if its worht payin 100 dolars for an install kit and if getin the wear pattern right is hard because i dont want it to make any noise. so what shuld i do
Old Feb 23, 2007 | 03:14 PM
seawolf06's Avatar
Get a professional to install it and get whatever kit they recommend.
Old Feb 24, 2007 | 06:51 AM
87DJP2001's Avatar
Your idea of changing gears from 2-series carrier (2:73) to 3series gears (3:42) won't work unless you can find a spacers for the gear set. Also its going to cost in the $500/700 range with parts & labor. So is it worth it for you.
Old Feb 24, 2007 | 09:09 AM
mdacton's Avatar
just get a new set of gears that fit your carrier, unless you have your 3.42 carrier
PCLZ28
Dec 24, 2015 05:19 PM
David Dorris
Jan 17, 2015 08:10 PM
97SSdude
Dec 31, 2014 07:43 PM
ModdedNerd
Dec 18, 2014 10:52 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
