need help guys...(clutch)
ok heres pretty much what i think is wrong THE CLUTCH, its a 94 z28 original clutch with 50k on it. why am i posting this bc, there is a high pitched squeeling coming from the center of the car (throwout bearing????) i need some advice because i want 2 replace it with a good clutch but im not trying 2 spend an arm and leg. it has slp headers, and slp loudmouth (both 2 be installed as soon as winter is over) as well as new cam and possible spray this summer. total hp when all is said and done should be roughly 375-400 hp and 400-450 tq, i need advice as to what make 4 clutch, new flywheel? nething else i should look into? and nebodys input here would help, possible set-ups as well as advice... aim is proc2k3 ill be on almost all the time bc im home due 2 surgery on my arm. trying 2 do this clutch work while im laid up at the house 2 cut down on time i would need a car. need help guys thanx!
I have similar mods you will have including nitrous. I changed out my stock clutch to a Spec stage 3 and used thier steel flywheel. I think its the best clutch I have ever owned including the SLP LT4 disk and preasure plate with holes in it. I have had zero problems other claim to experience. I broke it in for 500 city miles (took forever). From that point on I beat the heck out of it everyday with occasional full throttle shifts on the bottle. I have no compaints.
Hopefully you have someone to help get that tranny down since you just had surgery on your arm.
I installed a spec last year to instantly find out it was defective making me do two clutch swaps in 2 days. The pressure plate wasn't milled flat so it didn't sit correctly on my freshly cut flywheel. So, I wont buy spec again. They have great customer service, though ...
I exchanged it for a McLeod that I haven't installed yet. I'm currently running a Zoom that I "borrowed" in a pinch to get the car out of my friends garage waiting for the McLeod to come. Haven't swapped them yet, but the Zoom is holding up great.
