new gears got whine
Old Mar 10, 2007 | 08:09 PM
rique71's Avatar
new gears got whine
ok i installed 3.42 gears on my car a couple of weeks ago ,and from the time of the install they have been whining whenever i start coasting. the mechanic told me that it is because all the parts i used for the gear swap were used and that the gears were probably whining already. is that so? any other possible causes ? would like to stop the whining. thanks in advance.
Old Mar 11, 2007 | 12:30 AM
Jared 3870's Avatar
No knocking you wrenching skills, but it could very well be a poor install, or possibly some glitch. If they are out of alignment they would wine, wear, then break.
Old Mar 11, 2007 | 06:53 AM
rique71's Avatar
i didnt install them a mechanic did, he told me it was because the gears were used
Old Mar 11, 2007 | 09:51 AM
myslowcamaro's Avatar
not to sound like a dick, but anything goes on used parts. you get what you pay for. the mechanic who installed them have previous experience installing gears? might not be shimmed correct or backlash might have too much play.
Old Mar 11, 2007 | 09:55 AM
Z-RATED94's Avatar
What brand of gears are they? Some are louder than others. And don't forget, you bought used.
Old Mar 11, 2007 | 10:06 AM
mdacton's Avatar
backlash isn't going to cause any whine, Its probly the pinion depth is off.....did he acctually set it up or just put it in with the factory shim....All housings are not the same.
Either way, a used gear is going to have some noise anyway....pop the cover off and check it out with marking compound .....if the pinion depth is too far off it will break pretty quick.
Backlash wouldn't couse any whine unless it deosen't have any backlash or if it is maybe under 8 thou it could be meshing too deep and make some noise
Old Mar 11, 2007 | 05:13 PM
rique71's Avatar
yeah i except the fact of buying used is a risk of course . just wanted to know if it could be anything else, i will get the pinion depth checked
Old Mar 11, 2007 | 05:32 PM
mdacton's Avatar
you don't need to go that far...marking compound will tell you if there is a problem
good luck
Old Mar 11, 2007 | 05:51 PM
slp97camaro's Avatar
it could easily be the backlash on the gears. backlash will cause a whine if there is not enough. the backlash specs for the pricision 4.10 gears i put in my car, were from .007-.010 and mine were causing a whining noise only on deceleration/coast because i put it around .006
after i fixed it though there was no more whine...but theres also a very good chance its pinion depth too
Old Mar 11, 2007 | 06:05 PM
rique71's Avatar
what exactly is marking compound?
Old Mar 11, 2007 | 06:09 PM
mdacton's Avatar
its this thick greay paint type of stuff....you paint it on with a little brush and rotate it around. Then you look at that, probly find you a chart and it will tell you whats up...Also while you have the cover off backlash is easy to check
Old Mar 11, 2007 | 06:10 PM
danhr's Avatar
mine was orange
Old Mar 11, 2007 | 06:27 PM
rique71's Avatar
how do u check the backlash?
Old Mar 11, 2007 | 06:30 PM
mdacton's Avatar
with a dial indicator, put it on a ring gear tooth....backlash is the slop or the play in between the ring and pinion....too much it will feell sloppy and cluncky not enough the gears could be too tight to each other and cause the whine.
On a street car you probly want 8-10 thou
Old Mar 11, 2007 | 06:40 PM
rique71's Avatar
would autozone have the marking compound and the dial indicator?
