ring and pinion question
Old Mar 8, 2007 | 07:13 PM
195TA's Avatar
Just checking to see if the ring and pinion from a late 80s iroc will work in my 95 trans am. My trans am has the 2 series carrier and I recently upgraded to 4:10 richmond gears(big mistake). The iroc is a 342 probably the 3 series carrier gear ,which i have the spacer in my rear end to make that work. I guess what I am asking, are they the same ratio.
Old Mar 9, 2007 | 01:46 AM
195TA's Avatar
gears
anybody?
Old Mar 9, 2007 | 07:59 AM
Capn Pete's Avatar
Are they the same RATIO?? Or did you mean same RING gear size?? If that's what you meant, then yes, they're both the 7.5" / 7.625" 10-bolt .
I wouldn't recommend using the spacer behind the ring gear, but hey, that's your call . I REALLY wouldn't recommend being too hard on it, or things could go bad in a hurry .
What was wrong with the 4.10's, anyways? And did you know you could have bought them specifically for a 2-series carrier, where the ring gear would be made the extra ~1/4" thick, thus not requiring a spacer?? Now you know .
Old Mar 9, 2007 | 05:34 PM
195TA's Avatar
Thanks for the info,sorry for my lack of knowledge about the terminology. The 410 was also used but barely,that why I went with it in the 1st place. I had 1st planned on using the car for just a toy but its not gonna work out that way so thats the reason for wanting to get rid of the 410. I had originally thought that I had the 3 series carrier but after disassembling and starting to put it back together I found out real quick that wasn't the case. It has held up really well with the spacer and been to the track several times. So, you really do think they will be interchangeable?
Old Mar 9, 2007 | 07:38 PM
87DJP2001's Avatar
3rd & 4th Gen 10-bolts are the same thing and all the parts are interchangeable if they are the same 2-series or 3series.
Old Mar 9, 2007 | 09:07 PM
195TA's Avatar
Well the gear that im getting is either a 323 or a 342 which both would be a 3 series carrier if I remember correctly. my rear end that I will be using is for a 2 series carrier but I already have the spacer that I used for the 410 install. SO... if you guys a right then I shouldn't have any problems.
Old Mar 13, 2007 | 03:31 AM
Capn Pete's Avatar
You got it .
Old Mar 13, 2007 | 11:04 PM
Make sure your 3rd Gen IROC does not have the 9-bolt B-W Australian rear, with the 7.75" ring gear. Those will not be interchangeable. Look at the "sticky" on the Drivetrain topic page to identify the 9-bolt.
oldschool
Feb 9, 2016 09:21 PM
ChrisFrez
Feb 1, 2015 08:26 AM
TitoPR221
Jan 29, 2015 08:00 PM
4586
Jan 3, 2015 07:22 PM
derty
Aug 31, 2002 12:28 AM
