Replacement transmission line options? Part #'s?
I cut my factory flare fittings off b/c they were rounded out from excessive use.
I reflared the fitting but I'm not happy with the way it came out, I don't want to risk anything with the transmission so I'd rather just replace everything.
My two options are:
Go to the dealer and order a new set of lines (I need a part number if anyone has it)
or
Replace it with AN fittings and line (expensive $$$)
If I go AN I do not want to replace the case fittings, I absolutely will not risk cracking my case at this point. I know the earl's part # for the inverted flare, but I have no idea how to make AN line, what I need, or where to start. If anyone has a list of all I need it'd be great.
Or, if someone has the GM part #, that'd be great.
My two options are:
or
10-31-2016 11:09 AM
