View Full Version : LS1 Based Engine Tech
- is this a good deal ?
- Loud exhaust with A4
- Help With Wiring Electric Cutout
- Torque
- SuperMAXX Headers
- How much horsepower would these mods add?
- Paccccccesetter!
- C5 Owners Inside
- spark plugs
- Tax return = Let the mods begin
- suspension?
- Piaa 1100X will they fit an LS1?
- SLP option...?
- Is this 98 a good deal?
- stock wheel weight
- Slp loudmouth and Long Tubes
- Pro 5.0 adjustable stop bolts??
- Is it worth it?
- What Do I Need
- Spark Plug Boot Heat Shield?
- maf 2002 z
- Spring installation
- Decisions... decisions...
- LMperformance?
- Need info ASAP (LS6 or LS1 Hotcam)?
- Introducing the Masc Performance ported LS1 throttle body!!
- would this work?
- ASAP: EGR pipe removal
- I need your stock good condition TB's :)
- WTF is this.
- SS Hood
- Long Tubes??
- Restart computer after oil change
- won't start unless press clutch very hard ?
- quick cutout question
- Whats the IAT hole on the TSP lid ???
- How much to ask for stock LS1 heads/cam?
- a4 ws6 vs m6 ss
- Eagle F1 GS-D3 (confused RE: Z or Y speed rating)
- Need A New Battery!! Get An Optima??
- Will I hit 12's?
- Cam swap questions.
- Stock '01-'02 Z28 Dyno Numbers?
- Lid shopping please give me info.
- Door making noise(not totally aligned)
- Cabin noise is driving me crazy!
- Vortech/LS1?
- lt1 guy needs help, might be buying a ls1 car 1/8
- loudmouth
- What's the proper way to adjust rockers after removal?
- 43rwhp from sheetmetal intake
- Not engine related, but...
- FlowTech long tube headers
- Is z28s spoiler useful???
- basic cam questions
- ?'s on a SS
- 01 ta or z
- what tool is needed to remove the fuel filter
- Traction control module
- Emissions Question
- Anyone in Chicago land with "off road" headers take their LS1 in for Emissions?
- Will a 2001 airpump fit a 98?
- Anyone's SLP ludmouth Vibrate at idle....
- What would you pay for 99 Firehawk?
- Mecham oval exhaust tip GP!
- t top shades
- Recalibration of speedometer...
- Service Engine Soon Light
- LS1/LS6 tech?
- Restrictor Plates
- bad o2 cause misfire on cold start?
- pedal sticking, think its vacuum problem
- Mti Air Lid Fitment issues ?
- SSRA might work 12.402@111.96
- No Idle, no codes?
- Got a question regarding cats/smog stuff
- mac mid length headers
- Which exhaust tips should I get?
- Whats with my oil pressure ???
- new cam from thunder
- head pull
- fan mod?
- Wow, Its Sooo Loud
- Wester's computer programming
- 98 ls1 hp rating
- $1000 to spend on Exhaust... What to do?
- 9sec 1/4 possible w/ this setup?
- Design of Exhaust tip........
- auto to 6 speed
- Open header!!!!!!
- header question
- Instrumentation Questions
- All with 2001-2002 LS1's, some important info I found concerning valvetrain noise.
- ****PAGING Whistler ******
- header part list
- Help me .........
- 12 second car
- tire rack referral code
- Anyone with BAD piston slap/oil consumption....
- Header poll
- another pushrod thread
- Edelbrock Headers??
- What's a good price to pay for welding?
- GMMG question
- cant turn off traction on 00' Trans Am?
- Car not running right after LT install
- regular or premium?
- SLP Loudmouth installed
- Anyone ever have this problem
- missed a gear
- 12" or 24" O2 extenders for LT's?
- How hard to swap out alternator?
- TSP Rumbler Catback!!
- Whats the best oil to use in my ride ?
- Bought my new cam!!!!
- 30th Anniversary Trans Am
- Airbox Part Number
- anyone drop in a ls1 in a lt1 car?
- FAST 90mm TB ->$620!
- Good intake mods...
- Proud new owner of an LS1
- best way to check rev limit...without program software?
- Whats next
- o2 sensor - bank 1...is that the driver side?
- Exhaust sound clips???
- rockers
- rockers
- Need help identifing springs from (SS) pictures inside
- 99 waterpump issue?
- M.A.F. Screen
- hotcam vs. TR 220/220
- where to get a 02 WS6 wheel?
- how many pcv are on my ls1 camaro
- oil temp
- wrecked it > the update.
- Anyone running a 232/234 595/598 112 LSA Comp cam
- Piston Slap: LS1 Block vs. LS6 Block
- Locktight on header bolts?
- Which Y pipe for the Flowmaster?
- panhard arm worth it?
- hypertech question
- anyone using the slp maf sensor?
- P/N for oxygen sensor
- Ordered my full exhaust set up!
- Bassani Exhaust?
- What year did they start making ls6 intakes
- Prothane motor mounts
- Weird Knock when turning
- anyone heard of these guys???
- Not you're typical cam question
- pvc
- an old subject: sfc's
- Smallest tire?
- Does a BOLT ON offroad Y exist for 98 LS1?
- 98-03 cobras
- SunCoast Creations SS hood, and SLP Cold Air Package
- Lats damn header bolt to get out?HOW?
- Yet another question about tires...
- frame damage..help
- Code P0402
- i just bought a 98 z!
- Flow Tech Headers
- Tuneup - where is fuel filter? PCV?
- 9 second 346 guys... Who ported your heads?
- Whats my rwhp around ?
- Which cam?
- Coil(s) relocation
- Piston Slap?
- which bfg dr's are better?
- Valvetrain noise...what's normal and what's not?
- patriot cyl head failure
- i want my 98 A4 to run 12s. am i on the right track
- Plugs GAPED AT .70???
- Replace plugs with new headers?
- off road y-pipe
- Hit brakes......defroster light comes on? WTF??!
- pace setters lt?
- Intake manifolds
- this is going to sound really stupid, what is a hot cam?
- maf
- Speed inc. True duals
- Torque curve question...
- need some basic mod info on a ls1
- Recalls ???
- 99 ls1 I forgot what I read but somthing about a master/slave cylinder update/mod?
- 3 hours to remove motor mounts...PITA
- Rotors
- How often to rotate tires?
- A cutout question
- Removing the Air Dam question
- Whats the difference in the z28 LS1 and the C5's?
- Mandrel Bent vs non mandrel bent
- Agressive driving
- Horsepower
- test drove a 98 T/A, oil pressure issue and questions...
- Hood performance
- Pain in the rear end fluid leak
- Check this idea out...
- sound clip request
- converters...
- Aftermarket lids & Performance gain
- NO OPtispark
- removing AIR...does it thow code or not?
- Need your input
- ls1 speedo wire
- 1/4 mile times
- 17X11 zr1 wheels with 315 tires
- C5 front brakes for 4th gen f-body
- knocking sound
- sweet...
- part number for 01-02 ls1 slave cylinder?
- How much to get an airpump replaced?
- Headers or cam? money to burn...
- SLP MAF v. Granatelli MAF
- Ls1 Cam Install
- Maft
- cam?
- cooling system problem?
- Anyone ever use Gibson superflow mufflers?
- SES light
- headers
- Question about ls1 repair manuals
- whats best cat back exhaust?
- Why do 02 simms fail?
- light Squeeling noise might be pulley?
- suggestions on springs and shocks
- Security lug
- Ws6..???
- Asa Cam Size ? Asap !
- anyone with lowering springs...
- Pacesetter
- New Hood Raffle Registertion Site Is Up and Ready !!!!!!!
- I'm assuming this is some sort of scam
- Headers
- tire size, will it flare out?
- free mods are they really worth it
- 1/4 Mile Street times for stock LS1 SSs?
- Quick Question About Mgnaflow.
- Suspension Work
- raising rear seat pans to clear exhaust?
- free mods
- removing exhaust
- ...can the power steering pump eat fluid......
- Too big of tire?
- Car laggs when I shift hard
- Would a cut out give me the same hp gain as a catback ?
- Forged rotating assembly?
- Anyone had Body control module problems ???
- installing Electric cutout
