No Idle, no codes?
Old Feb 15, 2004 | 02:00 PM
wm_sorg's Avatar
Question No Idle, no codes?
I was wondering if anyone had any ideas of what's wrong with my car. It is off the road for the winter. I decided to run it yesterday and found the battery was dead. Recharged it and and it would not start until I gave it some gas. It runs but will not idle. The MIL light did not come on. I let the car run for about five or 10 minutes about 1000 RPM and gradually brought the idle down. The engine starts to surge and drop and eventually stalls.
Is it possible that the PCM lost it's custom tune while the battery was dead? Car has cam, pushrods and springs, rear o2s deleted.
When I hooked up the charger I heard a relay cliking for about one minute until I upped the amps from 2 to 6.
I imagine the batt might have been dead for two to three weeks? The car was exercised in early Jan with no issues whatsoever. Would the IAC go bad on an engine with about 7000 miles? Why no codes?
I appreciate all comments and suggestions.
BILL
Old Feb 15, 2004 | 02:38 PM
mullettour's Avatar
I had my batt unhooked overnight once to reset the computer. The next morning when I started it up it would not idle, but after running for about 10-15min it was okay. My car is stock though. I don't know if you lost your custom tune but it's possible. Good luck figuring it out.
Old Feb 15, 2004 | 03:51 PM
chpmnsws6's Avatar
keep giving it gas and drive it around a bit, it just hasta relearn what your engine likes
Old Feb 16, 2004 | 12:47 AM
AL SS590 M6's Avatar
Moderator
Go to the LS1.com main page and follow the link to the mods page. There you should find instructions for idle relearn jprocedure.
Old Feb 16, 2004 | 08:24 PM
wm_sorg's Avatar
Thanks for the help. I will give it a try when it gets warm enough. It was a wonderful 14 degrees when I got outside this morning.
Old Feb 16, 2004 | 08:27 PM
chpmnsws6's Avatar
yea, sucks don't it? its the same way here.
cars don't like being abused in this kinda weather.... things break
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
Chet1185
Apr 26, 2015 04:07 AM
lt1matt
Mar 21, 2015 07:35 PM
Gtpguy
Jan 26, 2015 04:50 PM
91Bird305
Aug 5, 2002 01:39 PM
