suggestions on springs and shocks
I am looking to upgrade my suspension a little bit. I want to lower my car, so it looks more agressive. I also want to stiffen up the ride a little bit, sometimes it feels like a boat, really dippin on turns. Now, I dont need the best. I need to consider the price along with the performace ( more agressive stance w/ a stiffer ride). I also have the 1le panhard rod and LCAs, which I havent installed yet
thank you
jp
thank you
jp
www.bmrfabrication.com
springs for 1" drop, $200
or
eibach prokit, 1.3" drop for $245
and bilstein HD shocks from www.bimmerparts.com should be $330
or
This is what I've got. It gave me what you're loking for.
H&R lowering springs:
1.75 inch drop (looks real good)
http://rksport.com/prod_detail.php?p...32&view=detail
Monroe Shocks:
http://www.shockwarehouse.com/cgi-bi...ks/search.html (ordering page)
They're no Bilstein, but I talked to a guy at the dealership, and he said they're definately an upgrade compared to the stock ones. (but he told me not to say anything
Hope this helps
Mike
Monroe Shocks:
)Hope this helps
Mike
I've got the Eibach Sportlines on my car. I think the drop is perfect. I haven't changed the shocks yet which will be the next upgrade, so any feedback on some shocks would be nice as well.
camaroz28.cardomain.com/id/thelaw
I just ordered a kit from Year One. It the SS suspension kit basically. It uses Bilstein shocks, progressive rate springs that lower the car about 3/4 inch, lower control arms, adjustable panhard rod, and a front sway bar. It is supposed to ride real nice and raises the Grip from .86 to .90. I will let you know how it rides when I get it at the end of the week. It costs 865 BTW.
I have an eibach pro kit (~$240) and KYB AGX 8 way adjustable shocks. The shocks were only 79 bucks each, i think i got them for 350 shipped from summit. you can also get a speed card and have 0 interest for 6 monthes aor a year maybe. other than that youll have to rent spring compressors and 2 new ball joint boots. the front shocks took a day by themselves, but id highly suggest doing the springs and shocks at the same time...it'll save on the time thing. Also, the pro-kit should lower your car about an inch, but i felt the back was too low, so i paid another 100 for adjustable spring perches and raised the back end up above stock. it looks like a beast now. before the spring perches id hit it, and the front was raising and the back sank like a beyotch. I also did this so the my 315/35ZR 17's wouldnt hit the rear quarters. if i had to go back, id keep the rear springs stock and put lowerings just on the front. there are places that will sell jus tthe fronts...
ZBLKHELLRZR
Aug 18, 2002 07:57 AM
