Security lug
Old Feb 4, 2004 | 01:36 AM
coogsLS1's Avatar
Security lug
I dont have a security lug socket w/my car. Where can I pick one up?
Old Feb 4, 2004 | 02:02 AM
99blackSS's Avatar
Are you saying you have a set on the car and no key?
If you have a set without the key, you will probably need some "ghetto" way of getting them off. The keys are different and have a number you need in order to get a replacement one made.
Old Feb 4, 2004 | 03:07 AM
coogsLS1's Avatar
what does the security lug look like? can anyone take a pic? Im pretty sure I have one.
Old Feb 4, 2004 | 12:34 PM
SSpdDmon's Avatar
Re: Security lug
I'm sure SLP sells them. But, I think they sell them in a kit with the four other bolts that go on each wheel. If anyone knows where to get just the 4 secuity bolts + the "key," I'd appreciate it. Mine have seen better days...
Old Feb 4, 2004 | 12:57 PM
camaronewbiess's Avatar
I got rid of my four wheel locks and replaced them with regular lugs. The wheel key strips after about 3 tire changes.
Old Feb 4, 2004 | 01:01 PM
T.V.'s Avatar
Step #1: Find socket slightly smaller than security lug.
Step #2: Attach to lug with large hammer blow.
Step #3: Remove security lug by turning counter clockwise.
Step #4: Replace with regular lug nut.
Step #4: Open beer and swallow contents.
Old Feb 4, 2004 | 01:04 PM
ZZed's Avatar
Remove the plastic lug covers. 4 lugs a hex (6 sided nuts). One is round with notches around the outer outside. You can't miss it. You can buy a set at www.lmperformance.com or a dealer. The do strip after a while, so make sure the key is on straight.
Old Feb 4, 2004 | 02:51 PM
99blackSS's Avatar
Re: Re: Security lug
GM sells just the security lug nuts and the key. I believe it was around $20. Could probably get it even cheaper if you call up the dealer and get the part number then buy them off of gmpartsdirect.com.
Old Feb 4, 2004 | 02:58 PM
SSpdDmon's Avatar
Re: Re: Re: Security lug
Cool...thanks!
Old Feb 4, 2004 | 04:29 PM
mullettour's Avatar
A friend of mine has a set of gorilla lugs on his truck. He lost the key and sent the key ID number in to them with $ and his address. They then sent him a key in the mail. I also have a set on mine (I dont know if they are factory or not because I bought the car used but they were on it when I bought it) the name of the company is Amcor. There was a card in the glove box with all the waranty information, window sticker, etc. The card says you can send in a $10 check or money order to them. If you have an ID card somewhere you should be able to contact the company and get a replacement if not. . .
Old Feb 5, 2004 | 03:20 AM
AL SS590 M6's Avatar
Moderator
I've got 3 sets that I'm not using.
A real thief is going to get your wheels anyway.
Jeff1904
Jun 5, 2016 05:00 PM
walt355
Mar 16, 2016 09:35 AM
Noct
Jul 14, 2015 01:18 AM
Jul 10, 2015 02:23 PM
