Instrumentation Questions
Old Feb 14, 2004 | 12:17 PM
moyam01's Avatar
I have always heard that the stock tach sucked. Now what I want to know is this because the PCM is not taking readings right or is it the tach itself? Thanks for the responses in advance!
Old Feb 14, 2004 | 06:26 PM
moyam01's Avatar
Can someone please help me I would greatly appreciate it.
Old Feb 15, 2004 | 01:02 AM
AL SS590 M6's Avatar
Moderator
The stock tach works OK if you're not going WOT.
Where they suck is that at WOT the motor revs faster than the tach sampling rate so the readings lag behind and you hit the rev limiter before the tach catches up. So you just learn your car and shift at the tach reading that =s just short of the limiter.
Old Feb 15, 2004 | 08:05 AM
moyam01's Avatar
So are there any aftermarket tachs that work with the stock computer that work good? I checked AutoMeter and they don't make one. Thanks I appreciate it.
silvermansteve
Mar 4, 2015 05:02 PM
Jan 5, 2015 07:14 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
Jul 4, 2005 05:00 PM
