Horsepower
Horsepower
Well the time has finally come i am finally swaping my v6 for an LS1 i found an 01 LS1 at a hell of a deal and was curious to how much hp these put out stock. any help on this would be great.
Drive a 1985 Honda accord for a month, then drive your 3.8 V6. That's the difference you will feel. I have owned both 3800 V6 and LS1 (current Z), and the difference is best described as "Holy Sh*t". Don't want to get too technical there on you bud.
You'll see.
You'll see.
forgot to add...
I saw some stock 2000 Z28 dyno results, as well as results of that same car after an aftermarket lid installation. They used the highest of 3 runs for both results.
Stock= 317 RWHP
Lid= 328 RWHP
That's pretty damn good considering they are rated 305HP, which I thought was at the crank. BONUS!
Stock= 317 RWHP
Lid= 328 RWHP
Originally posted by HoustonZ
forgot to add...
Stock= 317 RWHP
Lid= 328 RWHP
forgot to add...
Stock= 317 RWHP
Lid= 328 RWHP
Re: horsepower numbers
Originally posted by hurricaine418
not to switch gears here, but curious. i see the above numbers for rwhp, but whats a stock ls1 or w/ lid hp at the crank? how much lower than the 03 cobra? cobra 390 rwhp or hp?
Don't let these guys convince you that all LS1's dyno 300-320 RWHP stock. Some do but others dyno 280-300 RWHP. I have even heard of a few "slugs" that dynoed 275 RWHP. Then again I also heard of M6 "freaks" that dyno 320 RWHP.
01 & 02's will usually dyno in the 300-310 Rwhp range while 98-00's tend to dyno 280-295ish. Auto's also lose more HP in the drivetrain so some 01 & 02 autos might dyno just under 300. But once the modding starts they can do very well. 350-370 RWHP with bolt-ons and 400+ with just a cam!
Good luck with your new ride and welcome to the dark side
The factory rating (which is completely false
) is 305 HP for '98 - '00, and 310 HP for '01 - '02 Z28's and Trans-Ams. However, if you got the SS or the WS6, then they came with a different catback exhaust, as well as "ram air", so GM rated them higher, at 335 or 345 HP I think
. BUT, I think most guys would agree that the engine in ALL LS1 cars is still capable of closer to 345 - 350 HP, same as the LS1 Corvettes, but GM just underrates the F-bodies. If the engine didn't make 350 HP, then how would it be possible for guys to dyno over 300 RWHP?!
Don't believe internet dyno numbers ... people fudge 'em, trick 'em and dyno shops recalibrate so their numbers will compete ...
I dynod my '01 A4 at 278 rwhp stock ... never got more than 335 rwhp with all the bolt on's and 403 rwhp H/C ... and I consistantly out run other cars that have the "big" dyno numbers ...
Probably 5 - 10 rwhp more
.I agree that there probably are some "tuned"
dyno numbers out there, but I don't discredit all of it, because I'm also not convinced there is a 40 HP difference between the Corvette LS1 and the F-body LS1
. So, believing as I do, that the LS1 in the F-body puts out close to 350 HP (crank) then I think it's fair to expect 300 - 315 rwhp based on 10 - 15% drivetrain loss (or 280 rwhp based on 20% loss, which may be the case for your car?
).It's not uncommon to have 2 identical cars, motors, transmissions, and for one of them to simply out-perform the other one. That's why there is such a range in #'s for LS1 cars, no matter whether they're 98's or 02's
. Another point is that some have run into the 12's (12.9's) bone-stock, while some couldn't even hit 13's, such as my car, which only ran 14.1 @ 103 on its first trip to the track.
