Whats the best oil to use in my ride ?
Old Feb 12, 2004 | 10:12 AM
SpeedzAdisease's Avatar
Question Whats the best oil to use in my ride ?
I used Valvoline synthetic in my 00 civic si b/c it burned Mobil 1 too fast. Whats the best weight and brand of oil to put in my 98 z28. I'm not sure if synthetic has been used in my car. If not with 102,000 miles would it be ok to go synthetic ?????
Old Feb 12, 2004 | 11:23 AM
Buffdaddy's Avatar
I am not sure synthetic is good with 102k miles, but I know mobil 1 is one of the best.
Old Feb 12, 2004 | 11:29 AM
95GRNZ's Avatar
Wink
Not sure if such thing as "the best oil for my ride" even exists...
Everybody usually like the one they are using. Usually found through trial and error.
I used Mobil 1 in my LT1 from 74K to 114K (sold it @ 114K) and never had any problems with consumption. Didn't know what kind of oil was used before.
So, change to synthetic (my choice is Mobil 1, but there are others, too) and if it doesn't work well enough for you, try some other brands and if they don't work, then just use regular dino oil.
TS
Old Feb 12, 2004 | 12:36 PM
Omega9's Avatar
Mobil 1 5w-30 is all I use My car only has 23k miles though.
Old Feb 12, 2004 | 02:46 PM
psychocabbage's Avatar
34K miles..
amsoil and now mobile 1
always full syn..
Old Feb 12, 2004 | 10:16 PM
iateyour5.0's Avatar
I use Mobil 1 10W-30. Never had a problem with consumption, and even after being in a motor with 75,000 miles, it comes out at a pretty nice color. It's time to change the oil again, as a matter of fact. And I use Purolator Pure one filters.
Mike
Old Feb 12, 2004 | 10:19 PM
10w30 or 10w40 ??????????? Wich to use ????
Old Feb 12, 2004 | 11:14 PM
z28chrizz's Avatar
about 50% of the members here use Mobil 1... most say 5W30, like the vettes get from the factory.
Rest are split between amsoil, royal purple, and generic dino stuff.
Its all about preference. I run the Mobil 1, because it is what the vettes got, and I have had no problems with the car burning it. (altho i only have 27k on it) Its also easy to find, and one of the cheaper full synthetics when walmart has the 5 gal jugs on sale.
Old Feb 12, 2004 | 11:48 PM
camaronewbiess's Avatar
royal purple is primo stuff http://www.royalpurple.com/video/video.html
Old Feb 13, 2004 | 02:53 AM
WantobeZ's Avatar
hey I am new here, but I have been around oil for a long time. If you don't burn/leak oil then synthetic will work great, but if you do, running synthetic will make it worse. Eirher way a 5w 30 or 10w 30 will work.
hope that helps
P.S don't ever go to jiffy lube unless you are in need of new oil pan or motor.
Old Feb 13, 2004 | 11:00 AM
JKDGabe's Avatar
10w30. You want the least difference between the two #'s that you can get. You also want to run the lightest oil that will still maintain acceptable pressure. ~30psi at idle. Heavier oil will burn less but will give less lubrication when starting. Synthetic is best. You can get an Amsoil membership and buy it alot cheaper that way. And don't use Fram or other cheap filters! Wix, Amsoil, Mobil 1...
Old Feb 13, 2004 | 01:48 PM
Akshay's Avatar
I think it says to use 5w30 in the owner's manual?
If you don't have any oil leaks or oil consumption, use full sythetic 5w30.
Akshay
Old Feb 14, 2004 | 08:03 AM
Eliminator's Avatar
Old Feb 14, 2004 | 10:33 AM
TXZ28LS1's Avatar
castrol GTX 10w-30
Old Feb 14, 2004 | 10:49 AM
I know walmart has 5L jugs but 5 gallons?! OMG!
