SLP Loudmouth installed
Old Feb 13, 2004 | 12:20 AM
LetMeBurnU's Avatar
I finally got my loudmouth installed, i like the sound, but i hear some clanking and some rattling..........is this normal? anybody with a LM have the same problem
Old Feb 13, 2004 | 02:45 AM
Akshay's Avatar
Could be heat shield.
Akshay
Old Feb 13, 2004 | 03:02 AM
AL SS590 M6's Avatar
Moderator
Akshay
Yeah check the heat shields back where it goes over the rear end. Mine was hitting there. Had to loosen the clamp and rotate it just a little.
Old Feb 13, 2004 | 08:51 PM
LetMeBurnU's Avatar
Thanks! ill try that, hopfully that solves it.
Old Feb 18, 2004 | 01:04 PM
'00whitels1's Avatar
what kind of lm exhaust is it? is it the quad center mount or the regular lm with two 3" tips?
Old Feb 18, 2004 | 01:42 PM
if u look where the connection is made after the pipe bends over the axel you'll see that the pipes have come apart slightly. I have this same problem with my car because I have the same exhaust and it rattles loose on me sometimes. You could try to use a regular 2.5" u clamp with the two bolts and the one that came with slp and then jam nut the nuts. This might help out your problem, it's working pretty good for mine so far.
Old Feb 19, 2004 | 12:38 AM
LetMeBurnU's Avatar
It's the regular LM with dual slash tips on each side.
Nov 18, 2023 07:21 PM
Brake_L8
Jan 20, 2015 09:44 AM
brandboZ28
Jan 31, 2003 06:19 PM
vinnyxgunz
Aug 28, 2002 09:41 PM
jakeSS
Jul 22, 2002 06:54 PM
