Anyone with BAD piston slap/oil consumption....
Old Feb 13, 2004 | 11:49 PM
Nathan1234's Avatar
So my car has had really bad piston slap (duramax volume when cold, VW rabbit volume when hot) and used excessive oil since I bought it. This has never made me very happy. Last November (at 32,000 miles) I finally took it to the stealership and complained. They said "Holy crap, that thing sounds like a diesel ." I said "Ummm.... yeah, I know." So, after they talked to the big guys at GM, the best they could come up with was replacing all the rings.
Neither myself or the head technician though this would do a bit of good... but his hands were tied. They ordered the rings, and a couple of weeks later they were replaced.
Guess what... no difference. GM said to give it a few weeks and see if it got any better. Of course it didn't.
So, January rolls around and I take it back. Same technician looks at it and talks to GM. GM says this time we can replace the pistons with new pistons, and put the 'larger' pistons in the 'larger' holes. We all know that piston slap comes from an cylinder overbore (and so does GM), so how will this do any good?
I talked to the tech about it, and we were both pissed off about the whole situation (him because he didn't want to tear it apart again, me because it's my damn car). So, I got home and did some reasearch. What I found was interesting, and probably not commonly known: The LS1 only has .001" of tolerance for it's factory bore specification. I called one of my mechanic friends back home and asked him if a .001" over-bore could cause the sound I'm hearing. His response was "F*%k no, man. It'd probably take at least .003" over to get it to sound like that once it warms up."
So, I went back to the dealership a few days later once they had it broken down (heads off, pistons out) and took a look. Sure enough, #1 cylinder had visible scuffing at the bottom of the stroke. Piston slap doesn't effect the engine's reliability, eh? I talked to the tech about the possibility of it the bore being out of spec, and he said if it was, GM would have to buy me a new engine. #1 cylinder bore: 3.900"
This tuesday my new engine showed up at the dealership (with a corvette oil pan installed, oddly enough). They swapped the oil pan and hooked everything else up and.....
ZERO piston slap. It was 45 degrees outside, and not even the slightest noise from a cold start. I can actually HEAR the valvetrain!
Also, my last engine had the little 'bullseye' on the block. This one doesn't, and it's a bit less 'bright' than the other. I haven't checked the number on the back of the block, but I will tommorow. I think I already know what I will find.
Summary: GM sucks, and they let a lot of out of specification engines leave the factory in your cars. Bad piston slap does increase wear on your engine (visibly at 32K miles, I might add). Make them fix their mistake while you still have a warranty, or you will likely be paying for it at 125K miles.
Discuss.
Old Feb 14, 2004 | 12:55 AM
CrippleFightin's Avatar
Well sh*t! you got a new LS1 for free! Sure I'd be pissed it had to be done but happy that I now have 0 miles on my car from 32k!
Old Feb 14, 2004 | 04:11 PM
joSShua's Avatar
Ahhh, the mystery of piston slap is revieled to me. So was you car still under warranty when you got a new engine? My 99 is well past warranty, so the only thing to do in order to get it into specs to prevent piston slap is to make it a 383? Or get a new engine? Does piston slap get worse?
Old Feb 14, 2004 | 04:33 PM
mullettour's Avatar
Actually he got a new ls6 for free! Block that is.
Old Feb 14, 2004 | 05:15 PM
ULTIMTEORANGESS's Avatar
your engine might have been out of spec but that doesnt mean all ls1s that make a little noise are.most actually arent harmed by this.
thats good it was taken care of.
Old Feb 14, 2004 | 08:15 PM
jm8881's Avatar
I've never actually heard piston slap first hand, so I don't know what it sounds like. Anyone have a link to a sound clip of an engine with piston slap? LS1 perferably.
When I bought my car (used) I was about to ask the salesman about the LS1's buring a lot of oil and he told me that as soon as they got the car they tore it all down and put new rings in it. And it has a 12k mile waranty on the engine.
My car doesn't use any oil that I can see. Oil level didn't change one bit from the time I bought it to it's first oil change. But my car does make a slight knocking noise for the first minute or so after being started up when it's totally cold. But it's not really quick, if it is being caused by piston slap, only one is doing it. And it does get faster with the rpms.
Old Feb 17, 2004 | 03:05 PM
Nathan1234's Avatar
Just checked. It is an LS6.
HectorM52
Jul 30, 2017 11:46 AM
TitoPR221
May 26, 2015 12:20 AM
dylan1303
May 22, 2015 12:24 PM
drptop70ss
Mar 26, 2015 01:50 AM
1963SS
Feb 6, 2015 10:05 AM
